跳转到主内容
ASUS TUF Gaming F15 FX506L Left SSD Replacement
Clay Eickemeyer
Clay Eickemeyer2 其他贡献者
最后更新于 September 25, 2023
30分钟
中等
Follow this guide to remove and replace the Solid State Drive (SSD) in your ASUS TUF Gaming F15.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips screwdriver to remove the 10 screws securing the back cover:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • One 6 mm screw
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the clips: 步骤 2 中的图像 1,2 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the clips: 步骤 2 中的图像 2,2
    • Insert an opening pick between the bottom-right corner of the back cover and the chassis, near the captive screw.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the remaining clips: 步骤 3 中的图像 1,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the remaining clips: 步骤 3 中的图像 2,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the remaining clips: 步骤 3 中的图像 3,3
    • Insert your opening pick again between the top-left corner of the back cover and the chassis.
    • Insert the pick at a steep angle. Pry up to release the remaining clips securing the back cover.
  4. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the back cover: 步骤 4 中的图像 1,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the back cover: 步骤 4 中的图像 2,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Lift the back cover off the chassis and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Disconnect the battery: 步骤 5 中的图像 1,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Disconnect the battery: 步骤 5 中的图像 2,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Disconnect the battery: 步骤 5 中的图像 3,3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternating sides to 'walk' the connector out.
  6. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the SSD: 步骤 6 中的图像 1,2 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the SSD: 步骤 6 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the 3.6 mm-long screw.
  7. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD sleeve: 步骤 7 中的图像 1,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD sleeve: 步骤 7 中的图像 2,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD sleeve: 步骤 7 中的图像 3,3
    • Grip the sleeve surrounding the SSD near the screw indent.
    • Pull the sleeve straight off the SSD and remove it.
  8. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD: 步骤 8 中的图像 1,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD: 步骤 8 中的图像 2,3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD: 步骤 8 中的图像 3,3
    • Grip the edges of the SSD near the screw indent.
    • Pull it straight out of its socket and remove it.
    • If the SSD feels stuck, wiggle it side to side as you pull.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our ASUS TUF laptop answers community for help.
5等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
82,264 声望
创作了455篇指南
团队
Guide Team Guide Team 的会员
Staff
9 名成员
创作了11,494篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 55
过去 30 天: 256
总计 5,925
