跳转到主内容
ASUS TUF Dash F15 SSD Replacement
Spencer Day
Spencer Day3 其他贡献者
最后更新于 April 16, 2024
10 - 30 分钟
中等
Use this guide to replace the SSD on your ASUS TUF Dash F15.
Before you perform this repair, if at all possible, back up your existing SSD. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. ASUS TUF Dash F15 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 1,3 ASUS TUF Dash F15 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 2,3 ASUS TUF Dash F15 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 3,3
    • Remove the 14 Phillips screws securing the lower case:
    • Seven 8.8 mm screws
    • Seven 10.1 mm screws
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Dash F15 SSD Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 ASUS TUF Dash F15 SSD Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
  3. ASUS TUF Dash F15 SSD Replacement, Release the clips: 步骤 3 中的图像 1,3 ASUS TUF Dash F15 SSD Replacement, Release the clips: 步骤 3 中的图像 2,3 ASUS TUF Dash F15 SSD Replacement, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Repeat this process along the perimeter of the lower case to release the remaining clips.
  4. ASUS TUF Dash F15 SSD Replacement, Remove the lower case: 步骤 4 中的图像 1,3 ASUS TUF Dash F15 SSD Replacement, Remove the lower case: 步骤 4 中的图像 2,3 ASUS TUF Dash F15 SSD Replacement, Remove the lower case: 步骤 4 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. ASUS TUF Dash F15 SSD Replacement, Reposition the tape: 步骤 5 中的图像 1,2 ASUS TUF Dash F15 SSD Replacement, Reposition the tape: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers or your fingers to peel back the tape on the battery connector.
  6. ASUS TUF Dash F15 SSD Replacement, Disconnect the locking bar: 步骤 6 中的图像 1,2 ASUS TUF Dash F15 SSD Replacement, Disconnect the locking bar: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to gently push the locking bar away from the battery connector.
    • Make sure the locking bar is not covering the battery connector, or you may damage the battery connector's socket in the next step.
  7. ASUS TUF Dash F15 SSD Replacement, Disconnect the battery: 步骤 7 中的图像 1,3 ASUS TUF Dash F15 SSD Replacement, Disconnect the battery: 步骤 7 中的图像 2,3 ASUS TUF Dash F15 SSD Replacement, Disconnect the battery: 步骤 7 中的图像 3,3
    • Insert the pointed end of a spudger under the battery connector.
    • Pry under the left edge of the battery connector to disconnect the left side of the connector.
    • Repeat this procedure for the right side of the connector.
  8. ASUS TUF Dash F15 SSD Replacement, Unfasten the SSD: 步骤 8 中的图像 1,2 ASUS TUF Dash F15 SSD Replacement, Unfasten the SSD: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the 4.2 mm screw securing the SSD.
  9. ASUS TUF Dash F15 SSD Replacement, Remove the SSD: 步骤 9 中的图像 1,3 ASUS TUF Dash F15 SSD Replacement, Remove the SSD: 步骤 9 中的图像 2,3 ASUS TUF Dash F15 SSD Replacement, Remove the SSD: 步骤 9 中的图像 3,3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
结论
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
6等其他人完成本指南。
Spencer Day
于09/14/22注册
96,165 声望
创作了662篇指南
团队
iFixit iFixit 的会员
Staff
120 名成员
创作了19,665篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 194
总计 5,369
