简介
Replace the battery from your PadFone X.
工具
配件
没有特定配件。
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose.
Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose and remove the mid-frame.
Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
4等其他人完成本指南。
