跳转到主内容
加入维修社区 - 创建账户
ANKER SoundCore Battery/Battery Wire Replacement
你所需要的
  1. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: 步骤 1 中的图像 1,3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: 步骤 1 中的图像 2,3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
    询问修复机器人
    添加评论
  2. ANKER SoundCore Battery/Battery Wire Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
    • Remove the speaker mount gently.
    询问修复机器人
    添加评论
  3. ANKER SoundCore Battery/Battery Wire Replacement: 步骤 3 中的图像 1,3 ANKER SoundCore Battery/Battery Wire Replacement: 步骤 3 中的图像 2,3 ANKER SoundCore Battery/Battery Wire Replacement: 步骤 3 中的图像 3,3
    • Remove the two 8mm Phillips #0 screws from the circuit board.
    • Remove the circuit board from its mount.
    询问修复机器人
    添加评论
  4. ANKER SoundCore Battery/Battery Wire Replacement: 步骤 4 中的图像 1,3 ANKER SoundCore Battery/Battery Wire Replacement: 步骤 4 中的图像 2,3 ANKER SoundCore Battery/Battery Wire Replacement: 步骤 4 中的图像 3,3
    • Find the battery below the circuit board.
    • It is covered by fuzz that is the same color as the black casing, so it may be hard to see.
    • Pry the battery off using the iFixit opening tool.
    • Remove the battery from its holder.
    询问修复机器人
    添加评论
  5. ANKER SoundCore Battery/Battery Wire Replacement: 步骤 5 中的图像 1,1
    • Desolder the battery wires.
    • Remove the battery and battery wire from the device.
    • For more information on soldering and desoldering connections, follow this guide.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
Cal Poly, Team S22-G1, Regan Winter 2020 Cal Poly, Team S22-G1, Regan Winter 2020 的会员
CPSU-REGAN-W20S22G1
5 名成员
创作了7篇指南
6指南评论
If a bt speaker battery died,the unit can't power up by cable?
limz555 - 回复 分享
Nice guide… showed how to get the grill off… Unfortunately, my circuit board is epoxied in place.
Battery tests ok, but unit won’t turn on. Its going into the bag with other non-working electronics unless you have any ideas. The little speakers look very nice…
manfred.humphries - 回复 分享
My Anker works as long as it is plugged in (usb). As soon as the lead is removed, it dies.
David Goodacre - 回复 分享
Where do I get the new battery in India?
Raghubir Roy L - 回复 分享
What are the specs on the battery, so I can double-check compatibility for a replacement?
Andy Mattson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 123
过去 30 天: 432
总计 32,193
