跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
2016后期带功能键的13寸MacBook Pro显示屏组件更换
你所需要的
  1. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 禁用自动重启: 步骤 1 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 禁用自动重启: 步骤 1 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 禁用自动重启: 步骤 1 中的图像 3,3
    • 在开始此步骤之前,你必须禁用 Mac 的自动重启功能。自动重启功能会让 MacBook 在掀开盖子时自动开机。这个功能在拆卸过程中也可能会被意外触发。使用本指南或按照下面的简要说明来禁用自动启动。这项指令可能并不适用于所有 Mac。
    • 开机,并打开终端
    • 将以下命令复制粘贴到(或完全键入)终端窗口中:
    • sudo nvram AutoBoot=%00
    • [回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return
    • 你现在可以安全地关闭Mac电脑,并打开底壳,它不会再意外启动了。
    • 当修理完成、成功组装复原Mac电脑后,在「终端」中使用以下命令来启用「自动启动」功能:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - 回复
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - 回复
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - 回复
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - 回复
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - 回复
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - 回复
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - 回复
    Not able to do that with damaged screen
    richardjgreen - 回复
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - 回复
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - 回复
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - 回复
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - 回复
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - 回复
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - 回复
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - 回复
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - 回复
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - 回复
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - 回复
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - 回复
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - 回复
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - 回复
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - 回复
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - 回复
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - 回复
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - 回复
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
    Read the comments section at the bottom of the article before proceeding with the repair. It is unnecessary to remove the logic board. I actually removed the 45mm plastic bar to enable the cables to slip out then in. It is only there to frustrate repairers!
    Jack - 回复
  2. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 底壳: 步骤 2 中的图像 1,1
    • 在拆你的MacBook Pro之前,把电池的电放到25%以下。一个充满电的锂电池如果被意外穿刺,它会着火或是爆炸。
    • 在你进行下一步之前,先关了电源拔了插销。
    • 用P5五角改锥来拆掉固定底壳的这六颗螺丝:
    • 两颗6.2mm螺丝
    • 两颗5.3mm螺丝
    • 两颗3.4mm螺丝
    • 在整个维修过程中,请跟踪每个螺丝并确保它准确地回到原来的位置,以免损坏你的设备。
    Before any repair is carried out that involves removing the bottom case, the machines auto-boot function has be disabled. This can be disabled via the terminal command “sudo nvram AutoBoot=%00” once the repair has been completed the auto-boot function can be re-enabled via the vermin command “sudo nvram AutoBoot=%03”.
    Aaron Dalziel - 回复
    I recommend that you have an organizer tray for all the small parts, and label it in advance with the numbered “step” associated with each removal of screws and other parts. It really helped me when I needed to put everything back in reverse order, after the new battery is glued in place.
    tommy404 - 回复
    Finished the repair last week. Some key comments that helped me:
    - Step 12, Robert
    - Step 13, MikeG1
    - Step 13, Rick Jaffe (take a photo when disassembling)
    Also added some own comments on Steps 15, 18, 22
    Per Haglund - 回复
  3. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 3 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 3 中的图像 2,2
    • 在MacBook Pro底壳的前部中心位置嘬一个带把手的吸盘。
    • 抬起吸盘,在底壳和机身之间制造一道缝隙。
    To replace the bottom just line it up just like it came from the factory. Make sure it clears the display connectors. And press firmly down until the clips connect to the bottom again.
    olivia drinkwine - 回复
  4. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 4 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 4 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 4 中的图像 3,3
    • 在底壳和机身的缝隙之间插进一个撬片。
    • 把这个撬片滑向最近的角落,并继续滑到机身一半的位置。
    • 这会使第一个固定底壳的隐藏卡扣解锁。你会感到并听到卡扣打开。
  5. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 5 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 5 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 5 中的图像 3,3
    • 在另一侧重复上一个步骤,把你的撬片从下滑到上来打开第二个卡扣。
  6. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 6 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 6 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 6 中的图像 3,3
    • 再把你的撬片插进底壳的前部边缘,靠近最中间的两个螺丝口其中之一的地方。
    • 用力扭动撬片,来打开固定底壳的第三个卡扣。
    • 在另一个最中间的螺丝口处重复上述步骤,打开第四个卡扣。
    My 3rd and 4th clips released simultaneously with clip 1 and 2.
    Therefore I was looking to do something which had already been accomplished.
    David Hutzler - 回复
    yeah be sure not to bend those clips by the display bottom. You pull towards yourself to get it off
    Grant Tyler - 回复
  7. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 7 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 7 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 7 中的图像 3,3
    • 用力将底壳向MacBook的前端方向(与合叶相反的方向)拉,以此来分离最后的固定底壳的卡扣。
    • 先拉一侧,再拉另一侧,可能会有帮助。
    • 这可能需要用点儿力。
    Difficult to explain clearly, but worked easily for me by gripping the adjacent bottom and top corners then pulling in opposite directions, rather than trying to grip the hinge corner which is too narrow to afford a strong grip.
    Andrew Gordon - 回复
    This helped me. It needed more force than what I expected. Basically grab the corner with 6.2mm screw with one hand and the cover of that same corner with the other. Then pull the cover and push the laptop. Careful, it pops off with force!
    Javier De la Garza -
    I initially tried shifting the whole panel off the front after using the separating tool to make some space at the back where the hinges are. I only had luck when I pushed the panel back to it’s normal state and using the separating tool again to open the front, then getting my fingers underneath the slide it off the front was easy. I guess the lesson is to not use the separating tool to “push from the back“.
    Josh Brown - 回复
    This step really through me through a loop. My last two MBP were a 2011 and 2013 and on those the bottom just lifted off when you removed the screws. The clips and this sliding lock design added in the 2017 model was frustrating the first time. I was following a youtube video first and he did not explain the sliding part at all. I should have come here first, this guide explains it pretty well. The second time I opened my 2017, I kept an “opening pick” between the bottom panel and the body on each side, and used my two smallest screwdrivers as levers in both “front” corner screw holes. Used the same method without the picks to put it back together at the end. Wayyy easier that trying to grip the panel or laptop body. Just make sure the screwdrivers/pins that you’re using as levers are small enough to be loose in the screw holes and have room to move
    Jambu Atchison - 回复
    I used a pick underneath one of the back corners and nudge it (push down and towards the front - to get it off the hinge). This will make it easier to do the same for the other corner. The lower case will move off the middle plastic L-clips (which you will see after you inspect it.) Cheers! =)
    LSD - 回复
    I have found that your iFixit blue pry tool is excellent at giving me leverage to slide the bottom case forward to release it from the internal clips.
    themacdoctor - 回复
    the panel is sharp on the edges, sharp enough for you to cut yourself when pulling on it. i learned the hard way, just make sure your fingers are in a good spot before pulling
    Micah P - 回复
  8. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 8 中的图像 1,1
    • 摘除底壳。
    I used the green prying tool in the air gap at the rear to nudge the bottom forward.
    That is far easier and more reliable.
    David Hutzler - 回复
    David. I agree. I've found the blue iFixit prying tool most helpful. I place it with the curve of the tool around the hinge and move the bottom case towards the front to release it from the slide-in clips. I consider myself to have pretty good grip strength but I have had some bottom cases that just wouldn't budge until I used this method. Scott The Mac Doctor 
    themacdoctor - 回复
    Like Dave and "themacdoctor" said, this job is MUCH easier if you use a spudger or similar tool to gently push the cover away from the air gap, at the rear of the laptop. Once you do this, you've loosened clips that are on the inside of the bottom case. This is much easier than tugging on the case itself.
    ECJohansen - 回复
  9. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 电池接口: 步骤 9 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 电池接口: 步骤 9 中的图像 2,2
    • 小心地剥开这一大片盖住电池接头的胶带,它在主板最靠近电池的边缘。
    • 拿走这胶带。
    once the tape's back in place, it doesn't look tightly attached. not sure, did I do something wrong here or it should be so.
    Anton Monakhov - 回复
    The tape will likely not adhere as well as when it came out of the factory. This isnt an issue! As long as the tape is in place when the lower cover is put back on the device you should be good to go.
    Tarun Thiruma - 回复
    The underside of the tape is not uniform. Therefore, pay attention to which direction it is placed by looking at the underside when you remove it. Possibly mark one edge so that you can replace in the same direction during reassembly.
    Rick Jaffe - 回复
    Be very careful to ensure you're pulling the large rectangular patch of tape and NOT the little black tab on the data cable that is below. At first glance they look like they're all one piece. I made this mistake and think that I ruined that cable.
    Brendan C - 回复
    Mark one of the tape’s edges and, upon removal, stick it down with the same orientation. The first time I was inside the MacBook Pro (to upgrade the SSD) I failed to do this, and spent almost 30 minutes trying to get it back like it had been. Making a photo also helps.
    anasazi4st - 回复
  10. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 10 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 10 中的图像 2,2
    • 轻轻地剥开这个盖住电池排线接口的小片胶带。
    • 这段胶带和排线是一体的,不是完全分离的。只要把它剥开足够对电池接头进行操作的长度就好。
    There is no replacement for this cable in the new battery, is this normal?
    Marin dcv - 回复
    the replacement battery doesn't supply the small cable. It needs only be disconnected fro one end as in the pictures.
    robert - 回复
    Well the tape may not supposed to be able to separate but with gentle force, my tape just pulled right off leaving the connector still attached.
    John M - 回复
  11. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 11 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 11 中的图像 2,2
    • 用撬棒的尖头挑起这个固定排线的黑色小卡扣。
    If this ribbon comes off on both ends, how do you re-attach
    Gord Alder - 回复
  12. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 12 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 12 中的图像 2,2
    • 把电池数据排线滑出它的插槽来断开连接。
    • 滑的时候要在排线方向平行于主板滑动。
    the cable connector (where the twizzer tip is) should be cleaned with alcohol or acetone before insertion because the cover (where the tip is holding it back) will have glue deposit smeared on top of the connector circuit traces. Glue will prevent a good connection with the BMS.
    tarex7 - 回复
    The little tab that you pull back on, at least in my cable, was simple glued onto the rest of the cable. I tried to carefully remove the cable, and the tab came off. I did not have flat tweezers in the ifixit replacement kit and did not want to pinch the cable with sharp instruments. Therefore, be extremely careful when removing the tab as it is difficult to reattach the cable without it.
    Rick Jaffe - 回复
    Same problem with the tape coming loose and the cable not coming out. Go further back along the cable and pull gently on the cable with your fingers and the connector will come out easily.
    Robert - 回复
  13. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 13 中的图像 1,1
    • 把电池数据排线弯到后面去让它不要挡路。
    • 如果你要更换电池,则可能需要完全移除此电缆并将其转移到新电池上。断开两端并小心地取下电缆。在安装过程中,注意不要倒置或反向安装——注意照片中的方向。
    The new battery I received did not come with the battery board data cable, so I had to remove the existing one and transfer it. The lock at the smaller end is the same mechanism as the one at the end shown in steps 11 and 12, but smaller (and harder to see. It helps to gently straighten the left end of the cable before trying to insert it in the end of the replacement circuit board.
    MikeG1 - 回复
    I can corroborate MikeG1’s comment. My battery came without the long data cable as well. I had to remove it from the fried battery. Plastic lock tab mechanism on the ZIF connector is smaller. My inspection microscope helped to transfer the cable to the new battery board. Thanks Mike!
    Macrepair SF - 回复
    Likewise - the new battery came without a data cable. The cable was successfully removed from the old battery assembly and installed on the new battery, but it was tricky and nerve-racking (the cable is delicate and the connectors are very small) without instruction provided! The instructions should be updated to highlight the missing cable possibility, and provide information/illustration on transferring the cable.
    Marc - 回复
    In step 13, notice the amount of the data cable that sticks out of the connector. When moving this cable to the new battery, it is difficult to tell how far to push the cable into the connector or when it is fully inserted because the cable is so bendable.
    Rick Jaffe - 回复
    AMEN!! This was the hardest part of the ENTIRE process! Hard to know when the small end of the cable was “fully” inserted. Cable is SOOOOO delicate!
    Kevin McAda -
    If your laptop is showing the x where the battery icon is, this cable is at fault. This cable is referred to as the BMU (Battery Management Unit) flex cable. If it’s damaged, replacing it should solve your issue.
    Josh M - 回复
    my old battery was working but could not hold a charge very long so I replaced the battery and now my mac does not recognize the new battery. Thought it was a bad battery at first but I purchased a new batter and still the same problem, My mac will work off power outlet but does not register it has a battery at all now. I tried putting my old battery back on but i damaged the very small clip when i slid out the flex cable so its gone now. Could this cable be at fault? I don/t know what else it could be, i only messed with the battery.
    Leo Ruiz - 回复
    I have this same problem! Did you figure out what the issue was? Do I need a new flex cable?
    Jessica Mouland -
    I am having the same issue as Leo. After install. Is there a way to identify the fault?
    Nathan Jelinek - 回复
    Although the rest of fixit manual on this is excellent, this step is woefully lacking and the fact that the replace “kit” doesn’t have the Battery Board Data cable included makes the replacement kit significantly lacking (especially compared to other kits and instructions I’ve used before from them)
    zandar10 - 回复
  14. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 14 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 14 中的图像 2,2
    • 用一把T5 内梅花头改锥拆掉这个固定电池接头的3.7mm“薄煎饼”螺丝。
    When the battery management “BMS” circuit board is re-installed, loosely install the two 3.7 mm screws, put a spudger on the left side of the BMS board to wedge theBMS board to the right then tighten the two 3.7 mm screws. The reason for doing this is that the two power traces on the board may not make physical contact with the battery connector (connector at where the spudger is on step 15). One clue that you didn’t have physical contact is if you reinstalled everything but there is no power unless the AC supply is plugged in (with battery meter on the top at 0%). This was what happened to me. The reason is that when you bend the battery connector in step 15, it’s no longer in alignment with the traces on the BMS board and hence, you have to shift the BMS board to the right to compensate. Once I did this, voila 64% power.
    tarex7 - 回复
  15. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 15 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 15 中的图像 2,2
    • 用撬棒轻轻地抬起电池接头,断开电池。
    • 将接头抬起足够高使得它从插槽中分离。如果在修理过程中它意外碰到插槽,你的MacBook Pro有可能会受损。
    On disassembly note the position of the connector before you lift. It has two gold-plated connections on the underside. On reassembly these need to make contact with the matching battery board connectors. Bending the connector out of the way deformed it a bit, and on reassembly I could see that the connectors didn't align well with the board's connectors. I needed to adjust the battery board position to the left a bit by loosening the 3.1 mm screws in step 23. Possibly this could be the reason why some people report that new battery is not detected.
    Per Haglund - 回复
  16. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下铰链盖: 步骤 16 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下铰链盖: 步骤 16 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下铰链盖: 步骤 16 中的图像 3,3
    • 卸下用于固定显示屏铰链顶部塑料盖的四颗 1.9 毫米 T3 Torx 螺丝。
    • 取下两个塑料铰链盖。
    Be careful tightening these screw. Overtightening will shear the heads off of them.
    John Swinehart - 回复
    When reinstalling the plastic hinge covers, be sure to slide the bottom portion UNDER the rim of the unibody. If not when you go to reattach the bottom, it will not fully mate to the body.
    Earl Lynch - 回复
  17. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 断开主显示器电缆: 步骤 17 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 断开主显示器电缆: 步骤 17 中的图像 2,2
    • 卸下用于固定主显示屏电缆顶部铝盖的两颗 2.9 毫米 T3 Torx 螺丝。
    • 取下盖子。
    These are T4
    DarrenG - 回复
    Agreed. If you try tightening these with T3, you will partially strip them. Use T4.
    scentaur -
    For me, the left one (on image) are T3 and the right are T4! haha… I’ll put a pic here to show you guys LOL
    glecyo medeiros - 回复
  18. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 18 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 18 中的图像 2,2
    • 卸下用于固定显示屏电缆柔性连接器顶部的铝盖的两颗 1.7 毫米 T3 Torx 螺丝。
    • 取下盖子。
    These are also T4
    DarrenG - 回复
    I had a hard time getting a T4 bit to go into the one on the left, T3 worked perfectly. The one on the right the T4 bit fit just fine.
    arichard2401 - 回复
    Impossible for me to take out these screws.
    daleetstudios - 回复
    Can confirm, these are T4 for me, my T3 driver is just spinning inside
    Guillaume Turchini - 回复
  19. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 19 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 19 中的图像 2,2
    • 从插座中直接撬起显示板柔性电缆,将其与显示板断开。
    It actually clicks on and off—I did not pay attention when installing the new monitor and when I went to start the computer the screen did not have power but the bottom half came on (the hard drive fan went brrrr) this connector was down—but I had not “clicked” it on. It can be installed such that it will stay on without the metal strip that goes across it. The metal strip seems to be just to ensure it *stays* on. You got this!
    Mr. T. Monk - 回复
  20. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧下显示屏电缆盖: 步骤 20 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧下显示屏电缆盖: 步骤 20 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧下显示屏电缆盖: 步骤 20 中的图像 3,3
    • 卸下四颗 1.5 毫米 T3 Torx 螺丝,用于固定两条显示屏电缆顶部的两个铝盖。
    • 用镊子取下两个铝盖。
    These are mirror images of each other! Beware! In the photo you’ll see that in reassembly the “extra” metal bit goes toward the front. If you look at the underside of them you’ll see two foam bits: one square one to go over the flat metal part, the rectangle over the cable. With the extra metal bit toward the front (away from you) be sure you have the correct cover on the correct side!
    Robert - 回复
    This step may be unnecessary if you’re replacing the display. Check on your new display if these are already installed. If they are, skip this step. So far as I can tell, the only reason you do this step is on the off chance your new display does not have these two covers, they don’t really do anything to help remove or install the new display.
    arichard2401 - 回复
    Agreed with arichard2401. My replacement display came with both covers. Good idea to always be sure to inspect your replacement before beginning.
    Macrepair SF -
    Isn't it better to remove these two covers during reassembly to have less friction?
    Ludovic - 回复
  21. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧下天线组件: 步骤 21 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧下天线组件: 步骤 21 中的图像 2,2
    • 卸下固定天线电缆组件的两颗 3.3 毫米 T5 Torx 螺丝(每侧一颗)。
    • 还要卸下两个 4.1 毫米 T5 Torx 螺丝(每侧一个)。
    • 卸下用于固定天线电缆组件其余部分的十二颗 1.1 毫米 P2 五棱螺丝(每侧六颗)。
    I cannot find 1.1 mm P2 screwdriver heads, only 0.8mm and 1.2mm P@s seem to be out there…
    Jurgen - 回复
    Un reassembly, DONT OVERLOOK the placement of the “Board Flex Cable” from step 19. Make sure you don’t leave it imprisoned under this assembly. It needs to be lying over all this assembly.
    Macrepair SF - 回复
    When reinstalling the antenna cable assembly, on the front side of it facing towards the trackpad, there is a flat silver piece of metal. It needs to go into a little track in the MacBook. If it doesn’t, things will seem normal until you go to close the lid, and you will get a click.
    noahmadsen - 回复
    The screw drives of the P2 screws are extremely weak. Be careful when removing these screws and putting them back in.
    Maximilian Krause - 回复
    Those 12 tiny screws are a frickin’ nightmare. They appear to be P1’s, not P2’s , as all I have are a P0.8 and a P1.2, and the 0.8 just strips the heads. I did manage to get one out, but that’s it so far. I’m think I’m going to have to use my Dremel to make a slot for a tiny flat bit to get them out… Grrrr…
    jiclark - 回复
    i had a horrible time trying to get the 12 p2 screws out and i was ready to give up. i finally got them out when i applied really hard downward pressure onto my screwdriver. i really dug the end of my screwdriver into my palm. put some weight into it.
    ava saldana - 回复
    Oh man, be so so so so sure you aren’t stripping these tiny little screws. I got all of them out just fine with a P2, but one of them would just not come out and I ended up stripping it. Had to drill it out. Good news is that it will drill out really really easily with a 1/6 bit, just go really slow.
    arichard2401 - 回复
    anyone else have little dabs of cement along the 12 lcd cable screws? seems like apple tried to prevent me from doing this when they made it lol. 1/6 “ DRILLING IT IS lol
    Grant Tyler - 回复
    Maybe I could just drill out the stuck ones and only replace the ones that aren’t super messed up? Is that a stupid idea?
    Grant Tyler - 回复
    Hi Grant! Yes, that's a valid option.
    Arthur Shi -
  22. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 断开天线: 步骤 22 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 断开天线: 步骤 22 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 断开天线: 步骤 22 中的图像 3,3
    • 从主板上直接撬起两根天线同轴电缆,小心地断开它们。
    • 将镊子或撬棒滑到每根电缆下方,直到它靠近插座,然后轻轻扭动或撬起以断开它。
    • 要重新连接每根电缆,请将接口直接对准其插座,然后向下按压使其卡入到位。
  23. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 23 中的图像 1,1
    • 卸下将两根天线同轴电缆固定到主板的 2.8 毫米 T5 Torx 螺丝。
  24. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下天线组件: 步骤 24 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下天线组件: 步骤 24 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下天线组件: 步骤 24 中的图像 3,3
    • 使用撬片撬出所示区域中的天线电缆组件。
    • 不要左右滑动撬片,因为有两根显示屏电缆可能会损坏。
  25. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下天线组件: 步骤 25 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下天线组件: 步骤 25 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 卸下天线组件: 步骤 25 中的图像 3,3
    • 小心地卸下天线组件,同时将天线电缆束穿过机箱中的孔。
  26. 2016后期带功能键的13寸MacBook Pro显示屏组件更换: 步骤 26 中的图像 1,1
    • 卸下天线电缆组件。
    • 在重新组装过程中,轻轻地将电缆束捏在一起,并通过机箱中的孔引导到板上的正确位置。如果需要,请使用你的工具来帮助指导它,但不要强迫它。
    What is the function of this antenna cable assembly?
    Grant Tyler - 回复
    The antenna assembly contains the antenna lines for Wi-Fi and Bluetooth. Without the assembly, you'll have terrible Wi-Fi and Bluetooth reception.
    Arthur Shi -
    During reassembly after I put on the antenna piece the hinge would make a loud snap after being closed from a greater than 90 degree angle. After some trial and error I found a metal piece in the center of the antenna assembly that had to be bent back to fit in a grove in the aluminum of the computer. Hope that helps if someone is having a similar issue.
    Terry Brennan - 回复
  27. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧开显示屏电缆组件: 步骤 27 中的图像 1,1
    • 移除固定两根显示器电缆的弹簧铰链的四颗3.9 mm T3 Torx螺丝。
    These are T4 not T3
    DarrenG - 回复
  28. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 移除显示屏电缆组件: 步骤 28 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 移除显示屏电缆组件: 步骤 28 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 移除显示屏电缆组件: 步骤 28 中的图像 3,3
    • 抓住显示屏电缆组件的左侧,将其拉向MacBook的底端,然后远离弹簧铰链。
    • 使用一把镊子将显示器电缆的弹簧铰链从支架中拉出。
    • 使用显示器电缆组件的右弹簧铰链重复此步骤。
    YES, on reassembly it is possible to turn rotate the cover springs so that the ribbon is toward you. That’s wrong! It should lie down flat in the well of the laptop body. Be sure the ribbon is going DOWN and not draped up.
    Robert - 回复
  29. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧开铰链螺帽: 步骤 29 中的图像 1,2 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 拧开铰链螺帽: 步骤 29 中的图像 2,2
    • 重复此步骤,移除显示器电缆组件的右弹簧铰链
    4 + 2 + 2 =8 screws
    There are in fact only 6 screws on the bottom case .
    ianyounie - 回复
    I don't know if it's been edited, but I'm not seeing that. What I do see is they used 2 different colors for each of the sets of 3, and all six screws are the same.
    maccentric -
  30. 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 移除显示屏部件: 步骤 30 中的图像 1,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 移除显示屏部件: 步骤 30 中的图像 2,3 2016后期带功能键的13寸MacBook Pro显示屏组件更换, 移除显示屏部件: 步骤 30 中的图像 3,3
    • 牢牢握住MacBook Pro的屏幕和主体。在此步骤中,有一半可能会意外掉落。
    • 将MacBook Pro的两半推在一起,以便可以将铰链支架从机箱上的凹槽中提起。
    • 将MacBook Pro的主体向远离你身体方向推开,同时将屏幕拉向自己以将其分开。
    • 卸下显示屏/屏幕部件,注意不要将其挂在任何电缆上。
    • 在重新组装期间,请确保在重新固定铰链螺帽之前,显示屏电缆组件位于主体的正确侧面。
    • 确保确认显示电缆组件两侧的两个接口均已完全就位,因为在拆卸过程中它们可能会松动。
    During reassembly remember that the screen goes AWAY from you (as in the picture during removal). My cable was taped to the front of the display and had to be untaped and draped backwards over the bottom edge to get into proper position for attachment. Also, just in case this happens to you, too, the longitudinal rod that carries the springs and hinges was about 0.5mm too long to fit into the recesses. I had to file the rod down very slightly to get it to fit.
    Robert - 回复
结论
将新的替换零件与原始零件进行比较 -- 在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
'''要重新组装设备,请按逆序执行上述步骤。
'将你的电子垃圾带到R2或e-Stewards认证回收商
维修没有按计划进行吗?尝试一些基本的疑难解答或搜索我们的答案社区寻求帮助。
79等其他人完成本指南。
由衷感谢以下译者:
en zh
91%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tarun Thiruma
于11/20/19注册
35,352 声望
创作了134篇指南
23条评论
This guide sucks really bad.. missed steps. so unclear about everything. crappy pictures, I suggest you re do this whole thing.
Eugene Baker - 回复
10-15 minutes is good plus reassembly, major steps are missed this can misguide someone
Mwango - 回复
Good guide for someone with experience. I would add a few extra steps with more details, including some additional warnings since having a beginner follow this guide could result in failure in repairing the device. PLEASE HAVE SOMEONE WITH EXPERIENCE PERFORM THIS REPAIR!
Genesis Soto - 回复
This worked perfectly and saved me a lot of money. Many thanks.
Andrew Brown - 回复
Maybe the guide was improved since the above comments were made, but I found this guide completely thorough and have used it on multiple machines without issue. Thanks!
brentp - 回复
great tutorial but my webcam stopped working after i replaced the screen… any ideas? also what cable is the camera one?
Ryan W - 回复
The same thing happened to me, I used my warranty to get a screen replacement. The camera works fine for now. I'll see how long it holds up.
Khalid Krackn -
I am definitely an inexperienced at this stuff. Followed it to replace my sons display. Could not get Genius Bar appointment for a month trying. I found this guide to be perfect. Took me 4 slow patient hours because I knew I would have to reverse the steps when finished , however I finished and my son is so happy. Thank you , Tarun and. IFIXIT.
vidrew - 回复
Great instructions! This computer is made not to be opened from average user so be very careful!Take your time and be patient.
todoricco - 回复
Whatever has been done to improve this review, I must say, it’s fantastic. Nothing was missed. Brilliant repair guide. Thanks!
Rafael Pol - 回复
I have never taken apart a laptop before and this guide made it a complete success!
My only bit of input is that I found many instances where the T4 tip worked better on screws that the guide called to use T3.
Tim Costello - 回复
I replaced my broken screen using this guide. Guide is superb. Did not need to watch a video. This was the first time I ever opened a macbook pro.
On the criticism side: I agree with other commenters that steps 17 and 18 requires a T4 torx screwdriver, not T3 as stated in the guide. Additionally, step 29 requires a T8 torx screwdriver, which isn’t listed as a required tool. I happened to have a T8, but this repair could not be completed with the listed tools only.
Thanks again.
baturay aydemir - 回复
That's interesting. I was provided a T8 screw in my repair tool kit.
Khalid Krackn -
Nicely done and clear. One possible improvement:
Step 21 now says:
Remove the two 3.3 mm T5 Torx screws (one from each side) securing the antenna cable assembly.
Also remove the two 4.1 mm T5 Torx screws (one from each side).
It should say:
Remove the two 3.3 mm T5 Torx screws (one from each side) securing the antenna cable and display cable assemblies.
This is not an important change when you are REMOVING those screws, but it’s important when you are re-installing them, because it will encourage you to install the screws onto BOTH the antenna and display cable assemblies…
jimbreese - 回复
I'm with brentp — there was absolutely nothing wrong with this guide. I've also used it several times.
Charles Geiger - 回复
The guide made it easy the tiny screws made it tedious and the magnetic tools made it all possible.
GOAvendano - 回复
When removing the P2 tiny screws from the antenna assembly, make sure you press firmly and twist very slowly first, in order to avoid stripping your P2 driver, which can happen very easily. We've lost a couple to this already, and we use them to open iPhones too, so take care of them! Also if you break your P2 tip in the middle of this job and you have none other, you're literally SCREWED! hahaha :)
Felipe Leal - 回复
Great guide, and it covered everything in a simple and easy to understand way!
My only critique is that step 20, removing the display cover cables is unnecessary. Unless the replacement display assembly didn't come with those.
Shmajay - 回复
I think you need to since they're screwed down. Otherwise, I don't see how else the display covers would come off. I had to unscrew the covers to unhinge the display springs in order to remove the screen since they're attached.
Khalid Krackn -
I agree. I have used these instructions twice, and each time was successful. The only thing I would suggest iFixit is to add to the kit is a magnetic mat for all the screws placement, so nothing is lost nor forgotten where each one goes.
Khalid Krackn - 回复
This guide worked great for me. Reading through the comments on the various steps was beneficial. There were a couple points where I needed to use a T4 screwdriver tip vs the T3 tip mentioned, but other than that, all the steps are clear and the photos a great help.
roan horning - 回复
Can you provide help and easy way to replace screen
Samson Tang - 回复
Excellent guide, just remember that P3 screws are very delicate, so be gentle while working them.
niclet - 回复
添加评论
浏览统计数据:
过去 24 小时: 28
过去 7 天: 267
过去 30 天: 1,183
总计 88,279
