戴森 Dyson v6 Absolute 电池更换
简介
转到步骤 1戴森v6 Absolute 在3.5小时充电后可以提供20分钟强劲不间断的运行(标准模式下),并且电池可以轻易的取下进行更换。
你所需要的
找到电池上的螺丝
使用Philips #2 螺丝刀来拧下电池上的螺丝
On my V6 which is quite old it was a Phillips head screw but definitely smaller than a #2. I don't know the actual size, however. It was also hard not to strip the screw.
It’s a # 1 Phillips screwdriver, if you have the iFixit board of screws it’s on the top row, or bottom whichever way you look at it and 4th over from the side or the middle one which says #1 above it on the felt black color. I’ve got the Dyson SV06 animal Pro. IF YOU HAVE ONE WITH THE HEPA FILTER ON THE BACK IT Could be a different size but I doubt it.
找到手柄上的螺丝
Please specify what type of screw is used on the device handle.
Phillips……..
Bob Cook -
Habe zwei Staubsauger, bei denen sich diese Schraube dreht,aber nicht raus kommt!!!
Ute Rosner - 回复
向下将电池从设备上拆卸下来
Amazing, thank you
Vielen Dank für diese super Anleitung…….?
Flocke
Vielen vielen Dank für diese klare Anleitung,bin eine 71 jährige Oma und habe es ganz leicht geschafft!
Vielen Dank .
Bestens die Erklärung .
Per Video keine Chance gegg ja Abt .
Danke jetzt bin ich glücklich .
Musste ihn nicht entsorgen.
请按以下引导逆序重组你的设备
请按以下引导逆序重组你的设备
142等其他人完成本指南。
由衷感谢以下译者:
100%
Jerry Chen正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
30指南评论
very good article 10 out of 10
Great pictures, very straight forward, and I really appreciate you guys taking the time to put this together. I managed to “kill” my Dyson by getting a little over-zealous with the cleaning. I’m going to take it apart, let it dry completely, and hope that a new battery is the only issue. Anyway, your presentation has given me the courage to go forward - may not work, but…..
Hi, I bought my Dyson v6 for Christmas 2016. My battery only last few seconds at dis stage. It seems a short time for battery needing replacing. Is this normal .
I had the same problem with my dyson v6 slim. The battery didn't last long on mine either! I was very disappointed especially when you pay $500 for one of these.
Had the same problem. Before you go to the expense of a new battery, CLEAN THE LONG FILTER that sits on top of the barrel. If it gets clogged, the motor will stop. Wash thoroughly in warm water. All the muck is INSIDE the long filter. Rinse a few times to make sure dirt inside is all gone.
Air-dry for a few hours or with a hairdryer before using again. Don’t use vac while filter is moist… it will turn dust into mortar.
Hope this helps.
Rob -
It's important to keep ALL of the filters clean, or the power will start cycling on and off rapidly……. We got several years of power off of our 1st battery…… GO WSU COUGARS!!!
Bob Cook -
Fantastic instructions -precise and concise.
Thank you
Thank you for the excellent instructions!
Wonderful, simplistic directions. Kudos for posting.
Thank you so much, followed the guide and did less than 20 minutes x
Very nicely done Tabitha. Not too long. Not too short. Just right, as the three little bears would say.
Screws are PZ1, not PH2. It’s helpful to know which screwdriver to look for
Keith Gunn - 回复
Thank you so much for great instructions
When I pulled the battery pack off- a spring fell out… where does this go?
I find the screws too tight to undo and because it’s dark, very hard to see. Got correct screwdriver. It’s like they’re welded in.
Great instructions with pictures were easy to follow! Thank you!
Von was für einer durchschnittlichen Gebrauchsdauer kann bei so einem Akku ausgegangen werden? Wir haben unseren Dyson 2015 gekauft und er hat bis vor ein paar Wochen einwandfrei funktioniert, dann hat er sich von einem tag auf den nächsten nicht mehr einschalten lassen. Weil die LED’s am Akku beim Ladevorgang nicht leuchten ich bin von einem defekten Akku ausgegangen. Dennoch habe ich das Ladekabel aus der Wandhalterung entfernt und den Akku direkt angeschlossen, ohne Ergebnis. Wenn ich den angeschlossenen Akku prüfe liegt immerhin Spannung an, sobald ich aber den Stecker ziehe nicht mehr.
Ich habe es zweimal mit der Kunden-Hotline von Dyson.ch versucht und nach jeweils 45 Minuten Tonband entnervt aufgegeben. Die Kunden-Hotline von Dyson dient wohl in erster Linie dazu Kunden abzuwehren. Aufgrund dieser Erfahrung und des allgemeinen Geschäftsgebarens der Firma ist Dyson für mich endgültig gestorben, es gibt genügend andere Anbieter mit guten (oder besseren) Geräten. Unabhängig davon möchte ich ein ansonsten intaktes Gerät aber nicht gleich auf den Müll schmeissen. Wie finde ich also heraus, ob das Problem mit einem neuen Akku gelöst ist oder ob es am Ladegerät liegt?
I purchased the Abaige 3.8Ah V6 Replacement Battery - Compatible for V6 SV04 on Amazon. It came with no instructions. Having never disassembled my SV-04, it was not at all obvious (to me) how to assess the front screw on the battery. These instructions, along with the photos, were exactly what I needed; clear and accurate. I had the entire job done in less than 15 minutes. Very happy!
Echt klasse und einfach nachzumachen ?Realy easy and absolut good to handle?
How do I find out what model that I own?
Very good directions. Fast and easy. Thank you.
