跳转到主内容
如何用互联网恢复模式启动 Mac
  1. 如何用互联网恢复模式启动 Mac, 如何用互联网恢复模式启动 Mac: 步骤 1 中的图像 1,1
    • 关闭您的电脑。
    • 如果你使用互联网恢复安装macOS到新的硬盘,您可以跳过这一步骤。
    I thought this guide is for a completely new SSD, but in this example MacOS appears to already be running. Is the target SSD connected internally via SATA or is this guide for a USB based second SSD that will also run the OS?
    In the latter case, is the intent to run internet recovery on the new SSD and then open the machine up and connect it directly, replacing the old disk?
    orun bhuiyan - 回复
    Sorry for the confusion, Orun! The new SSD guide shares a few steps with the general “boot to internet recovery mode” guide. If you’re installing MacOS to a new drive, you can skip this step. :)
    Taylor Dixon - 回复
    Just to clarify, I have a late 2009 MacBook 6,1 running El Capitan and will be upgrading to a new SSD. Will Internet recovery work with this computer? The article states “after 2009”. Also I want to upgrade to High Sierra at the same time is there an option to select which OS or how does it decide?
    nathan davis - 回复
    My current hard drive won’t read. I don’t care about saving anything on the computer at all and had planned on starting fresh. Can i just install the drive then do internet recovery mode or do i still have to have a backup usb with the os preinstaled?
    J H - 回复
    Hi all,
    I recently purchased a Mac mini so that I could have iMessages on my Android phone. It was petty and so that my lesser than iPhone user people could stop complaining about the lack of blue messages.
    I ended up updating from the OEM hard drive to an SSD. I obtained a copy of Yosemite from the link below and installed an update to make sure it worked on the original drive.
    I had trouble with my Bluetooth keyboard so instead of going through all of that, I ran the installer again but selected my new drive and install the iOS onto the external drive without any issue. I then installed the SSD and it is working so far. Knocking on wood.
    Hope this is helpful and I haven't done anything wrong or caused anyone any issues.
    nick peloquin - 回复
  2. 如何用互联网恢复模式启动 Mac: 步骤 2 中的图像 1,1
    • 当电脑完全关闭以后,先按下电源键,并立即按下并按住command + option + R键。
    Does this option still work if using a Bluetooth keyboard?
    Chad Neumann - 回复
    Chad, this option should still work if using a bluetooth keyboard. If you’ve paired the keyboard to the computer already, then it should connect quickly enough to register the keypresses. That said, it’s definitely less reliable than using a wired keyboard! And every bluetooth keyboard is different—one might work, and another might not. Good luck!
    Taylor Dixon -
    In my case, the SSD was completely new, and the only way I got internet recovery to work was to press Cmd+Opt+Shift+R, which installs the macOS version which came with my Mac (a Late 2012 21.5’’ iMac).
    Adrià - 回复
    If you have a PC/Windows keyboard plugged in, then use Window+Alt+R for youngest compatible Mac-OS download.
    Ian Kjos - 回复
    Thanks for the tips! The BT keyboard didn’t work so I used a handy Windows one.
    lucas -
    MacBook 2009 A1342 DOES NOT WORK, it always shows the ‘folder’ with a ? inside and there is nothing i can do. +, i already bought a copy of Lion 10.7 on app store but cant access it either HELP PLEASE ;-)
    Simon Saint-Pierre - 回复
    Mine shows the same thing a folder with a ?, I couldn’t copy my hard drive as it crashed and the computer wouldn’t boot up. Now I’m starting with a brand new ssd I need to know how to or what to do.
    sweetbrandigirl2004 -
    On my MBP mid-2012, the Cmd+Opt+Shift+R worked for me too with a brand new SSD. Thx Adria!
    cat. - 回复
    Oui pour moi aussi, avec mon MBP 13" mi 2012...
    Mickael Cambray -
    I have the A1224 and i can’t get to that back screen, I’ve tried com+opt+R and also opt+com+shift+R. It just go straight to log in screen. Any ideas that might help me get there?
    Art - 回复
    I have MacBook A1280, I have tried all the keys combination but none is working. Keyboard perfectly working on pc but can't access Mac os partition.
    Michael Deborn - 回复
    For me, press together button to turn on + option worked
    Ana Beatriz - 回复
  3. 如何用互联网恢复模式启动 Mac: 步骤 3 中的图像 1,2 如何用互联网恢复模式启动 Mac: 步骤 3 中的图像 2,2
    • 当出现旋转地球的动画时,您便可以松开按键。
    • 当互联网恢复启动时,小地球会开始旋转。如果您没有使用有线连接,“选择网络”会出现。通过这个菜单将电脑连接到WiFi。
    when i want to input wifi password the keyboard is not working
    pika - 回复
    Mine just gets stuck at WiFi connection…
    Kelly Cairns - 回复
    Hi.
    In this step choosing the network I can't type my password to get my connexion.
    It shows me locked.
    Thanks
    Francisco
    Francisco Hernandez - 回复
    Hi,
    In this step after connecting to WIFI it will be there forever no progress. If I click on another network it’s getting error’ed out with a globe and exclamation mark in it and error is “apple.com/support -1005 F”.
    Please assist me with some information on how to overcome this phase.
    Raghu.
    raghuvaran45.rv - 回复
    Hi
    did you fixed it?
    i had same problume can you help me
    thank you
    vazisda -
    -3511 F Eror , whats does it means?
    Shuhrat Safarov - 回复
    Mine is stuck flashing a folder with a question mark on it. Now what?
    lauren borkowski - 回复
    cant get passed folder with ? mark inside PLS HELPà
    Even if your keyboard is AZERTY, write your password as using a QWERTY one. Just did it now.
    You're welcome ;)
    Nicolas Vaché - 回复
    thank you sooooo much
    Geraldine Portal -
    I can’t get passed this… entered WiFi password and it just spins forever trying to login…
    Tom Baker - 回复
    Same to me… did you fix it?
    Fritz Denner -
    Cela ne se connecte pas alors que le code est bon, comment faire ???
    coraline.mauna - 回复
    Bonjour, je rentre mon mot de passe wifi, mais cela me refuse l’accès ?
    Ebrard Alexis - 回复
    faite attention si vous êtes français ou autre et que votre clavier est en azerty, car moi j’ai finalement compris que dans le ordi c’était en qwerty voilà pourquoi il n’acceptait pas le bon mot de passe
    Marine Leclaire - 回复
    After connecting to the network, globe keeps spinning, no progress bar appears underneath. Please advice how to proceed. Thanks
    miguelcruden - 回复
    After inputting the WiFi password it gets stuck on the revolving globe showing 24:00 for ever. What might be the problem and how to fix this issue? please help!
    Srinivasa Rao Buddha - 回复
    Solution: You need to set your DNS-server to 8.8.8.8 at your router.
    Pavel Veter - 回复
    If you are in Malaysia and using Time Internet, this will not work. I used my mobile phone (Maxis) and a hotspot to get around the problem. Not sure if its the way the router is configured with my Time connection.
    james_abela - 回复
    Indeed. Cannot get past Time internet and need to use the hotspot. Thank you very much james_abela.
    Y MY -
    A solution for me when stuck on entering wifi password and nothing happening was instead tether to my phone, i.e. mobile hotspot and that fixed it
    Lorenzo Monsif - 回复
    I put the wifi and then it gets me stuck on the password part, I’m unsure if I type my devices password or my wifi password
    Olivia - 回复
    You need to act as if you have an US keyboard with the order QWERTY and not QWERTZ that also fixed my issue
    ay luna -
    Another issue I’m having is that whenever it finishes to load my computer turns off and then I’m back on the globe screen. I really need help.
    Olivia - 回复
    So no answer for somebody with the same problem of flashing folder with question mark? I have a MBP 2010, upgraded to 1TB Crucial SSD. Opt- CMD- R only gives me flashing folder with question mark. Come on Crucial , help out. Thanks!
    BBfreak 8 - 回复
    I wrote the good password in the US keyboard. But it’s still loading how can it works? I only see something charging without any progress…
    Can someone help me ?
    manon - 回复
    The typical problem when you get a flashing folder with a question mark on the screen is a problem with the hard drive. If you have changed the drive for a new one it might not be compatible or poorly seated, or you did not start internet recovery correctly/in time. If you have not changed your drive and your Mac suddenly have gotten this error, the hard drive is most likely defective and needs to be replaced, in my experience. @bbfreak8
    Roger_L - 回复
    Nel momento in cui inserisco la mia password, la rotella dell’attesa comincia a girare ma non fa niente per ore. Ho provato diverse volte ad accenderlo con lo stesso procedimento e non fa niente. Se cambio password me la dà errata. Come posso risolvere?
    Francesco - 回复
    I am not able to type the password for wifi.
    Please help
    praphul singh - 回复
    As with other comments here, I'm on the screen to select my network, and the roadblock is the password. I put in the password for the network, gets bounced back. I try my password for the Mac itself, gets bounced back. Apple ID, gets bounced back. It's not specific as to what password it's looking for, but nothing works. A ridiculous flaw with seemingly no solution! Makes me think twice (or more) before buying any more Apple products in the future. My shortlist for the holiday season was an entry level MacBook Air and an IPAD, but now I'm not too sure if we have to look forward to more of this sort of thing.
    Michael Selinger - 回复
  4. 如何用互联网恢复模式启动 Mac: 步骤 4 中的图像 1,1
    • 当建立了网络连接以后,进度条便会出现在小地球下面。
    • 这个模式容易超时。如果你收到错误信息,请尝试用有线连接来链接互联网而不是使用WiFi。取决于你的电脑型号,你可能需要适配器来进行有线连接。
    Coloco la clave wi fi la reconoce pero no me carga nada, se queda conectado pero sin cargar nada
    federicorabanez - 回复
    de que año es la maquina? Podría ser que la red no tiene conexión? Tal vez pueda probarlo con una conexión por cable.
    Taylor Dixon -
    Coloco la clave wi fi, y la reconoce pero el globo continua rotando hasta que se detiene y muestra error casi que indefinidamente. Algunas veces se congela y muestra error 2002F… no se que hacer
    Luis Hartmann - 回复
    Hi, what if nothing happens once a connection is established? It just connects to the wifi and then goes back to previous page
    Allie Wilson - 回复
    Hi
    I get the spinning globe and progress bar, then it goes to grey screen with apple logo and spinning loading icon then just goes to grey screen :( 2011 macbook pro.
    Plz help.
    morgan phone - 回复
    It happened the same to me! Could you find a solution? Thanks
    Christian Cinetto -
    I have exactly the same problem on a 2011 macbook pro, nothing happens after the internet recovery loading
    furansu-182 -
    And I have the same problem on my pro 15 2011😔
    defsokal -
    I cannot type in my password, that includes numbers. If I want to type in for example number 3, instead a # appears. Is there a way to fix that problem?
    Kaweh1395 - 回复
    The process just skips the Wi-Fi connection process. It loads the disk utility but no Wi-Fi connection. Try to load operating system it says you need Wi-Fi connection? How do I get to Wi-Fi connection process?
    jim anderson - 回复
  5. 如何用互联网恢复模式启动 Mac: 步骤 5 中的图像 1,1
    • 当互联网恢复加载完成后,您就会看见macOS恢复界面。
    After I entered password and loaded up internet recovery a Question Mark appears and flashing. What do I do next?
    Dennis Fessler - 回复
    Never mind. When I tried a second time it went to the Disk Utility. I was able to complete the process.
    Dennis Fessler - 回复
    Quanto tempo ci mette di solito a ricaricarsi Internet Recovery ???
    Betty Bi - 回复
    Apple und die Time Maschine die alles kaputt macht. Statt Itunes hätten sie lieber die Time Maschine raus nehmen sollen aus Catalina Betriebssystem Apple
    Planet der Giganten - 回复
    mi Mac lleva más de una hora y está hasta la mitad de la barra
    Matías Fonseca५ప - 回复
    A mi me carga hasta la mitad luego se reinicia,mi máquina tiene el problema que se reinicia constantemente pero me deja acceder al modo seguro
    asesino97ful - 回复
    Can I backup data from internet recovery to an external drive before reinstalling operating system?
    Sara - 回复
    So, if I have a time machine backup, I chose that? I am replacing my SSD and going from the stock unit to the 1G.
    acm332 - 回复
    Bonjour
    Merci pour votre article.
    J’ai une question à laquelle je n’ai trouvé aucune réponse. Comment désactiver la mise en veille lors d’une clean install? Je dois rester constamment rester devant l’écran pour éviter une perte de connexion et un temps d’installation plus long…
    Layanah - 回复
    I tried. It it didn’t go beyond globe and I tried for couple of hours. Pls advise
    San D - 回复
    Saludos. Al entrar el password pasan unos minutos y se apaga. Que puedo hacer?
    Melissa - 回复
    it doesn’t send me to macOS but to a white screen, what do i do?
    julia - 回复
    I have te same problem. It finishes the load screen, and then the screen turns white, the laptop starts to get hot and then turns off...
    Tobal -
    Same, white screen with little apple in middle. Did you guys figure it out?
    Jennifer Casares -
    nach dem runterladen bekomme ich eine Fehlermeldung. Habe keine Festplatte angeschlossen.
    Hab beim löschen versehentlich mcOS nicht sofort neu installiert
    Ceddi^-^ - 回复
    After following all the steps and waiting an hour I get message
    Can’t download additional components to install Mac OS system
    Whe press OK goes back to start and again does same after an hour ?
    Ant advice ?
    Amr
    Marzouk - 回复
    What size it takes? It writes "About 13 hours and 27 miniutes remaining.
    What is the system size??
    Plz
    Esmail Alsawraqi - 回复
结论
从恢复菜单中,你可以从时间胶囊恢复你的备份重新安装 macOS,获得在线帮助,或者使用磁盘工具格式化或者解决任意连接的储存设备的问题。
69等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Taylor Dixon
于06/26/18注册
69,522 声望
创作了94篇指南
44条评论
Apparently PowerBook G4 12” does not work for restoral based upon this exercise?
72Yonatan - 回复
Oh, I’m so sorry! I forgot to specify: internet recovery mode is only available on newer Apple computers. I’ve updated the intro now, sorry for the confusion!
Taylor Dixon -
So a mid 2009 computer won’t have internet recovery mode?
Carlos Perdomo - 回复
I bought a Asgard (seems operates from HongKong) 2TB NVME PCIe M.2 SSD that I installed into mackbook pro 15in mid 2015 with sintech adapter for conversion to MacBook AHCI controller. The disk utility does not show this SSD. Later I installed in same way another Sabrent SSD 2TB it worked fine.
What might have gone wrong in the fist SSD. Could that SSD itself faulty or incompatible? any fixes available?
GBish - 回复
Two main reasons:
- You aren’t pushing deep enough your new ssd drive into the slot. Please reopen your mac, unplug the battery connector and push the new ssd to a fashion position.
- Your are missing the Alt/Option key. Please make the full shorcut: Alt+Shift+R.
Orlando Gomez -
Hi there
I recently replaced the HDD in my iMac 2019, 27” Retina 5K with a OWC 1TB SSD which I formatted before installation. After installing the SSD drive my iMac won’t boot up. I’ve tried everything but to no avail. When I turn the power button on nothing happens unless I continuously hold it and then only the fan comes on. Do you have any ideas what could be the problem?
Joseph
JOSEPH BROWN - 回复
Hey Joseph! There are a couple things that could be wrong here. I recommend you follow the steps laid out in this Answers post: iMac will not power on except fans, and when you get to the SDRAM step, instead put back the original HDD to see if that works. (Not that that’s the permanent solution—it’s just a problem solving step.) Hopefully it’s just a loose connector somewhere!
Taylor Dixon -
So I’ve followed these instructions and nothing happens. I reach the screen that shows the spinning globe but then it just stops. The Apple logo appears and sits there inactive. It never updates with the reinstall screen and there no options to update, either via the time machine back up or to reinstall the MAC OS system.
Nicholas Thomas - 回复
Forgot to state, I have a mid 2011 27” iMac.
Hey Nicholas, since you’re on the tail end of the compatibility list you might need to force your EFI firmware update. You can find the download link here: EFI firmware update list. If you’ve already done that (or you don’t have the ability to boot back into macOS anymore), I would try again with a stable, wired internet connection.
If you can’t get internet recovery to work, you can always create a bootable macOS drive with another macOS machine and use that as a recovery drive in a pinch. Hope this helps!
Taylor Dixon -
help me please, i want to reset my MacBook pro but when i'm click command+R MacBook show like step 3, but i can't input wifi password because my keyboard can't working but the capslock button is working. so what can i do?
pika - 回复
pika, try plugging in an external keyboard to input the WiFi password!
Taylor Dixon -
I need help please!! I’ve chosen the wifi for the laptop to connect to but it’s just takes me back to the spinning globe and the wifi options. It doesn’t show that it is loading. How do I fix this so I can move forward to the next step?
Gigi - 回复
Hey Gigi! It sounds like either your WiFi password isn’t correct, or the computer can’t connect to the internet with that network for some other reason. I would try your password again, and if that doesn’t work you can try to connect using an ethernet cable—or just take it to a friend’s house and try their WiFi!
Taylor Dixon -
Hi! I have followed these steps, the world is spinning and there is a time bar and under the bar is 24:00 and it has been stuck on there for over an hour, it never popped up and asked me to input my wifi information either? Help!!
Danielle Starr - 回复
Danielle, that’s a weird one! Normally the time bar only shows up if you have slow internet, but if it didn’t ask for your wifi information then that’s definitely unexpected behavior. Can you try using an ethernet cable to hardwire internet to the computer? That way you won’t need to use wifi anyway, and hopefully it will be able to boot to internet recovery. Hopefully that workaround will get the job done, keep us posted!
Taylor Dixon -
Time Machine doesn’t work, reinstalling the OS X doesn’t work, and system utility doesn’t show my hd . What do I do?
johnthompson111 - 回复
J’arrive à l’avant dernière étape et après celle là la cinquième étape ne s’affiche pas et m’en remet sur «  saisissez le code pin de verouillage de votre système pour déverrouiller ce Mac «  je n’arrive pas à aller à labo dernière etape
Lou - 回复
J’arrive jusqu’à la quatrième étape mais après sa me met saisissez le code pin de verouillage de votre système pour déverrouillé ce Mac je ne comprend pas
Lou - 回复
Hi I have done all of the above steps and the globe remain spining but instead of the progress bar it simply has the new of the WiFi connection under it? Any help? Kinda panicking a little here
Pj Reilly - 回复
What if it says to select the disk where to install macOS Big Sur, but no disk is showing, it just lets me click back
David Hall - 回复
Hello, I have tried the above steps but everything stopped after the bar is fully loaded and shows a “Warning Sign” in the world icon with “apple.com/support", underneath it is -2100F.
Please what can I do next?
David Ebong - 回复
Hello,
can you help me please ?
how can I leave this mode?
The combination keys I mean
Regards
MacBook Pro 2018
Abdoulaye Cissé - 回复
Utilities does not come up for me only after the spinning globe a page to choose language pops up and then the options to shut down or restart are prompted
moh Visions - 回复
I’ve been trying to get back to the Home Screen but it won’t let me
Sue Burgess - 回复
recovery stop with error 1008F
H K - 回复
Spinning globe and internet connection but no progress bar. What can I do?
bigolddogman - 回复
Hi! What’s does that mean:
Earth with triangle with “!” plus that text
apple.com/support
-3403F
Thanks
christian
Christian Spindler - 回复
PS: tried it several times and checkt netzwork cable/internet connection - was O.K. but Then it was successful. Happy whis understands that…
&&^& u apple headed bitxhs
showtyme2828 - 回复
I am ok up to step 4 but unfortunately the Mac OS utilities screen doesn’t appear. Only le apple logo
Mps - 回复
I hade this error when going to recover mode -2002f
Prakash Chavan - 回复
Bei meinem 27", Ende 2011, lässt sich die Prozedur auslösen und der Ladebalken unter der Weltkugel öffnet sich, doch nach 30sek. stoppt der Ladevorgang und ein Uhrsymbol zeigt 24:00. Was bedeutet das?
Wig Hensi - 回复
At the bottom of the screen that says activate Mac it says select wi-fi network and in the upper right hand corner it has the apple logo and recovery assistant. How do I get my MacBook pro to restart
Taris Brown - 回复
After connecting to the internet my Mac keep showing the globe and the option to chose a network. Do you know how to fix it ? Cheers
Abner lucas nogueira - 回复
Ant advice ?
Amr
Marzouk - 回复
It get to a screen that looks like a phone or something with a swipe button, then something that looks kind of like a tablet screen and it’s showing a power button on the side.
Gordon Browne - 回复
Hi my mac crashed and now i am not able to boot via usb nor the internet. After restarting and pressing the command option r my mac comes up with a lock logo which asks for a password which i donot remember. I have put in all possible passwords but cannot go past it. Kindly help!
Yogesh Chand Thakur - 回复
Very helpful and I was able to be successful at restoring my system. Thank you. Now for the next task and accomplishment to achieve.
Indigenous Willd Flowers - 回复
Super useful, worked for me!
Fernande Tester - 回复
Old iMac Issue:
Tried installing macOS from Utilities, but received the message 'macOS system can't be found.' How can I fix this?
umi - 回复
Salve intanto ringrazio per quello che sono riuscito a vedere ,ma volevo dirvi che io per fare uscire il quadro del recovery devo attivare solo il tasto alt, pero' non si riesce ad arrivare alla conclusione, potete voi aiutarmi? perchè sono nei guai con un Macbook pro 15 retina del inizio 2013, sicuramento sarò senza sistema operativo senza sapere come e successo, spero di avere una risposta grazie
Michele - 回复
Michele
Michele - 回复
Penso di aver detto sopra quello che mi serve Ringrazio per l'aiuto che mi potete dare
Michele
Michele - 回复
添加评论
浏览统计数据:
过去 24 小时: 131
过去 7 天: 793
过去 30 天: 3,248
总计 522,325
