跳转到主内容
修复Oculus Quest 2 的摇杆漂移现象
Seizure Salad
Seizure Salad7 其他贡献者
最后更新于 January 18, 2025
5 - 25 分钟
简单
社区贡献指南
在长时间使用Oculus Quest 2后,其摇杆可能会出现漂移,导致你的游戏内人物在你并未做动作的情况下缓慢漂移。在这指南中,你将学习如何解决摇杆漂移的讨厌问题。
如果你想替换手柄中的摇杆模组,参考这份指南。.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. 修复Oculus Quest 2 的摇杆漂移现象, 从手柄里拆下电池: 步骤 1 中的图像 1,1
    • 打开电池仓,移除里边的 AA 电池。
    Better ways to do this. This is proven that it wrecks the controllers joystick and it will make the joysticks life span shorter by ALOT.
    Mark Zuckerberg said NOT to open the joystick compartment on a tweet, when fixing the Joystick drift issue. Look up different ways, or just send it back and spend a couple of bucks from a professional.
    WARNING DO NOT OPEN YOUR CONTROLLER AND PULL THE JOYSTICK!
    You have been warned.
    Ryo DerpDog - 回复
  2. 修复Oculus Quest 2 的摇杆漂移现象, 移除手柄前面板: 步骤 2 中的图像 1,2 修复Oculus Quest 2 的摇杆漂移现象, 移除手柄前面板: 步骤 2 中的图像 2,2
    • 移除黑色的塑料前面板。你可以选择使用iFixit出售的拆机工具 Jimmy ,或是使用一个一字螺丝刀。
    • 塑料面板的下面有双面胶固定,第一次拆解可能会比较困难。无需担心拆掉双面胶的影响,面板由另外的塑料柱牢牢固定。
    I can't even get the plate off without breaking it so now it's even worse thanks alot
    Jacob Galloway - 回复
    with enough effort you can get it off without breaking it
    Seizure Salad -
    you can also use a lego brick dissembler
    Quincy Epoo - 回复
    This does work, I used a Lego brick dissembler as another comment said. Just be gentle and wiggle it out. Do not force it because it will break, it is plastic after all.
    Tofu - 回复
    I completed this with a box cutter and four pins!
    tim. - 回复
    When I did this step I used a few guitar picks. The trick is to lift your way around the black circle. The first time I did this I heard a ripping sound from the guitar pick sliding AROUND the area and removing the adhesive. Do NOT just lift from one area. GO AROUND. Like opening a can.
    Aflannelshirt - 回复
    after removing the plate, will the adhesive hold it together still once I replace the plate?
    Jeremy Anderson - 回复
    The adhesive should still hold it in place but if not there are plastic clips that do firmly hold it in place.
    Seizure Salad -
    This helped me so much I could barely even play it was so bad bud I did this and now I don’t move at all 5 stars I thing I do want to note is that you want to be very careful and steady putting the joystick back on and not have it wobble around you could break that spring but overall 5 stars
    C T - 回复
    At first my joystick cap wouldn't come off, and the spring looked pretty firmly attached to the base, but after putting the cap back and taking it half off a few times it had enough and let go of the spring. Everything worked as expected, I can now stop moonwalking against my will. The buttons feel a little bit shorter after reassembly, but not to a noticeable degree while in VR, and everything still works.
    John Lorentzson - 回复
  3. 修复Oculus Quest 2 的摇杆漂移现象, 移除摇杆帽: 步骤 3 中的图像 1,1
    • 轻轻拉掉位于摇杆顶端的摇杆帽。
    • 盖子可能无法从触摸传感器弹簧上脱落。在这种情况下,让弹簧保持连接到操纵杆盖上,不要强行将其取下。如果这样做,很难在不损坏弹簧的情况下重新安装。
    • 在摇杆座和摇杆帽之间有一弹簧。不要弯折或是破坏它,它控制着触控传感器。
    if the spring is bent and cannot easily or at all be reinserted to all four brackets that hold it in is it broken will it work without issues or does it only track if a finger is torching it?
    Realfixerupper - 回复
  4. 修复Oculus Quest 2 的摇杆漂移现象, 清理手柄摇杆: 步骤 4 中的图像 1,1
    • 首先,向摇杆喷射一些压缩空气来清除其中大颗粒的杂物。
    • 接着,向摇杆内部滴加少量90%或更高浓度的酒精并转动摇杆。之后,静置以让酒精风干。
    • 确保只使用精密电器清洁剂或者浓度90%及以上的异丙醇。其他的清洁剂和物质可能导电,进而损坏手柄。
    • 在重新装好手柄之前,确保清洁剂或酒精已完全干透。
    This worked. Thank you!
    robertaccomando - 回复
    Does the spring need to be reattach the casing of the joystick? Or is it fine if I just put the casing on
    Parker Rist - 回复
    you don't have to worry about it just put it back on
    Seizure Salad -
    So if I only put on the alcohol and not the contact cleaner it will still work?
    Grady Spencer - 回复
    By a small amount of contact cleaner do you mean like a few drops or a few ml
    Dominic green - 回复
    What if the joystick won't come of?
    Trinity Gilley - 回复
    what would happen if someone used 70% isopropyl alcohol?
    captain_perez - 回复
    the high water content would damage the controller
    Seizure Salad -
    I did this with my first controller and it kinda worked but it never was as responsive as before, and over time got worse and worse.
    nate allen -
    Do you have a video of the steps to make it easier to understand?
    Kratos - 回复
    I didn't had 90% alcohol so I've tried glass cleaner - it worked only a little bit, so I've tried to apply more... And as expected controller stopped working completely. Had to disassemble the controller completely (using ifixit guide too).
    Then cleaned excess fluid from a board near joystick. Also, I've opened the joystick itself and gently cleaned it's parts. After re-assembly joystick now works as good as new.
    Vladimir Petrov - 回复
    Does the spring that’s located between the joystick have to be there or can I just take it off?
    alfredo reyes - 回复
    This worked the first two times but now it is obnoxiously out of control.
    It doesn’t work anymore and my controllers are perfectly normal. Any other suggestions?
    Mason Miller - 回复
    This guide worked! But I caused another issue somehow. Upon reassembly the joystick now makes a clicking sound when pushed to the bottom right corner and has developed drift. Do you have any suggestions for a fix?
    Adrien - 回复
    How do I clean it if the joysticks won’t come of
    Carlos - 回复
结论
要重新组装手柄,只需以倒序执行前面的指南。如果你需要演示这些步骤的视频,这里|new_window=true]可以找到。
80等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Seizure Salad
于01/12/18注册
2,686 声望
创作了2篇指南
团队
Master Techs Master Techs 的会员
Community
327 名成员
创作了1,673篇指南
49指南评论
I did that and it works, but now the touch sensor on the thumb stick doesn’t work. Any ideas?
briangerrard - 回复
The spring that goes between the joystick housing and the cap is what connects the touch sensor to the controller. While i did not inspect the cap to see for myself i believe there should be a metal contact on the underside of the cap that the spring should be touching.
Tl;dr: Make sure the spring between the joystick cap and housing is properly connected to both sides.
Erik Sørhage -
Thanks, just what i needed.
Just one problem.
You never mention the spring that goes between the joystick housing and the cap. I understand that you took it off completely to get a better picture, but to me it seems better to not take it off completely and just let the joystick cap hang by the spring while you spray cleaner down into the housing. As long as you're careful not to bend or break the spring i believe this would lower the chance of the touch sensor not working like one of the users here already have problems with.
Otherwise the guide is good and on-point.
Erik Sørhage - 回复
I should mention tho, i bought my quest on day one so perhaps my controller is an earlier model. On my controller the spring between the joystick cap and housing wasn't easily removable from either side, which is why i decided to leave the cap hanging. It could be that on later models the spring is not connected to the cap but instead is just pressing up against it.
Erik Sørhage -
The spring is still there! It might be a bit hard to see however and I’ll note that in the guide.
Seizure Salad -
after putting the faceplate back on the buttons are slightly shorter pls hepl
Balls HD 4K - 回复
Make sure all the plastic posts click in place I and that you didn’t break any of the posts
Seizure Salad -
can you find a way you can do it without compressed air or any other paid air or cleaning products
Eli Brown - 回复
Late reply, but these are the bare minimum for doing a fix like this. I mean, you could try blowing really hard with your mouth, but you can't really replace contact cleaner or 91% isopropyl alcohol. You should really have at least a bottle of 70% in your house anyway, it is an important first aid item and can also be used as a sanitizer for kitchen surfaces mixed in a spray bottle with water and a single drop of dish soap.
You do not want to use water or any water based cleaners like dish soap for this fix. There's a reason that was pointed out. You will ruin the rest of your kit.
Anthony Potter (WardenPlays) -
Any suggestions for a broken thumbstick cap? The base is cracked and I can't seem to find anywhere that can replace or repair it.
Julie Eves - 回复
AliExpress.com - original controller joystick cap for oculus quest 2. $7.99
Deborah - 回复
When reattaching the thumbstick on older Oculus branded devices, grab the spring and spin the stick clockwise (righty tighty) until the thumbstick and spring get reattached. If you don't do this, your finger sensor won't work,
Lanes - 回复
I did all of the steps correctly and it's still sticking what should I do now?
michael pepka - 回复
I did all of the steps correctly and it is still sticking what can I do now?
michael pepka - 回复
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Martin Bunzl - 回复
Thanks for the guide! Very easy and fast. I just applied 4 drops of isopropyl alcohol, moved the stick a few times and waited about 15 min. for it to evaporate - but I tested it BEFORE putting the plate back. I recommend doing this test even BEFORE you open the controller so you can see if (or how much) it improves afterwards: wearing your headset, go to Settings > Devices > Controllers > Thumbstick Range and Deadzone > Calibrate. Move the stick around and see how it behaves (or misbehave). In my case it was jumping around very erratically, but after the procedure it was working perfectly! :)
Ricardo Ferreira - 回复
the controller still drifts a lot should i try to find a replacement joystick or just buy a new controller
elijah - 回复
It worked! I figured out that it helps a lot if you keep the battery on the controller when you unassemble it and try to move the joystick around with the oculus headset on and seeing when the stick drift stops, and when it does stop completely you can reassemble everything and it should work good as new! It's a relief playing games without worrying about my movement going wonky, definitely works!
saint - 回复
I wouldn't recommend keeping the battery in the controller however as you may damage it while you're cleaning it
Seizure Salad -
Worked superbly! As easy as this was, I honestly didn't think it'd work. It worked perfectly. Thank you!
Kitt - 回复
Thanks! This worked for me. I didn't have the iFixIt spray so I just poured a bit of iso alcohol over the joystick and spring. Then all I did was fidget the tick around to distribute the alcohol and let it dry. Instant fix
Shlum Hum - 回复
I'm having difficulty getting the cap off the thumstick
Matthew Mcintyre - 回复
Me too. I tugged until I felt like it might break if I pulled any harder. Also tried unscrewing it since some of the comments say you have to screw it back on for older models (but nothing about screwing it off), but was afraid to put too much force on it.
Chez Arctica -
you should be able to just pull it right off
Seizure Salad -
Now my joystick drift stopped, but whenever I move my joystick anywhere except to the bottom right, my oculus doesn’t think it moves at all. Help me please.
Drew Carter - 回复
It isn't a smart idea to tell people to take the controller apart this is absolutely terrible advice
Ms Bunny - 回复
ok??? there isn't really a good way to actually fix drift without taking the controller apart
Seizure Salad -
how else do you think internals get fixed?
CEO Ofnerds -
It's either do that or just buy one. At that point there really is no other choices.
Its like you telling people not to fix their cars.
Kevin Criswell -
Do you mean just regular stuff I put my contacts in or hydrogen peroxide
Quinton hillery - 回复
if you put isopropyl alcohol in your contacts then you’d be blind and hydrogen peroxide would damage the controller
Seizure Salad -
ignore the guy that is trolling, contact cleaner is a automotive electrical cleaner, WD-40 brand specialist contact cleaner is sold at lowes/home depot for 8$, normal WD-40 will damage your controller though so buy the right can
NecroNomad -
Just done this and I'm very happy to say it worked! Thank you so much, very easy to do. I hadn't played in a month or so and was devastated to find out I had some rather annoying stick drift. All I used was an air duster and a flat head and presto no more drift.
Highly recommend someone to do this if they have stick drift.
I made an account just to thank you lol
Zachary Hughes - 回复
When I put mine back together something happened where now the controller won't show up behind me
Austin Green - 回复
This is normal. Due to the way the Quest 2's inside out tracking works it won't be able to track controllers behind you unless you're looking at them.
Seizure Salad -
Hello
I don't have a problem with the joystick but with the rear trigger.
It's like pressing on it when I'm not even touching the joystick, so I can't interact or select games.
Abdel Larbie - 回复
Thank you very much. Now i can play 'Into the Radius' again, without constantly moonwalking 👍🏻
Oliver Latza - 回复
I went through the guide and now my controller's light constantly turns off and on rapidly, and won't show up when I try to use my Quest 2, how do I fix this?
Cy Hamm - 回复
I followed the instructions minimally and it worked for me. Much appreciated. I popped up the face plate, rubbed around the analog with cotton and 91% alc. I’m back in action now.
Ozzmon Dumas - 回复
This lies it doesn’t work at all I’ve been trying this for 2 months and nothing has changed
Titanvictory - 回复
Oh my goodness THANK YOU I cannot describe the pain of constantly moving to the left and alerting enemys In B&S.
Also the drift has just made me stop playing VR in general once again THANK YOU!
Innes Watson - 回复
Dose dawn ultra soap work?
Fix my conttroler - 回复
No, you will cause further damage to your controller.
Are you sure this works what if I tryed it and it still has drift
James - 回复
i reattached the plates and now my controllers don’t turn on
crev - 回复
I have just used some contact cleaner on my joycons the left works perfect but the right won't turn on now is there a way to fix it or have I broke it for good
MIKEBULLY345 - 回复
This worked perfectly for me thank you, had stick drift for so long got to the point of games being nearly unplayable, this has helped so much.
Jam_Guy - 回复
i followed this and shed a tear looking at the joystick calibration and watching how it didnt freak out everywhere
wadr - 回复
I followed this to fix my left controller drift, and it totally fixed it.
JP Lizaola - 回复
添加评论
浏览统计数据:
过去 24 小时: 40
过去 7 天: 338
过去 30 天: 1,719
总计 209,415
