跳转到主内容
三星Galaxy Tab 10.1吋主板更换
Davie Sy
Davie Sy6 其他贡献者
最后更新于 August 1, 2019
30分钟
中等
在本指南中,您将学习如何更换Samsung Galaxy Tab 10.1吋上的主板。 主板出现故障可能导致许多部件问题,特别是如果您的设备无法启动。 有一些先决条件,我们需要解决!
你所需要的
工具
查看更多...
  1. 三星Galaxy Tab 10.1吋主板更换, 后面板: 步骤 1 中的图像 1,2 三星Galaxy Tab 10.1吋主板更换, 后面板: 步骤 1 中的图像 2,2
    • 将平板电脑的底部朝向您。
    • 用Tri-Wing螺丝刀卸下充电端口附近的两颗4.1 mm螺丝。
    Access denied! The screws near the port are covered by buttons. I wedged a pointed screw and hammered "gently" until they popped out. Problem solved!
    Daniella - 回复
    My model doesn't have any screws!
    Barry - 回复
    What can I do if my model DOESN'T HAVE ANY SCREWS? It has a loose LCD cable so SOME of my colours are all mixed up. This is really frustrating so please help
    Janine Coetzee - 回复
    I have SG Tab Pro 10.1
    There are no screws..... now what?
    iloveto travel - 回复
    Great instructions! Easy to follow.
    skritzberger - 回复
    My model has no screws.
    Faith Odutola - 回复
    My model has no screws and doesn't look like the one pictured here. It's a model SM-T580.
    Elsa Kramer - 回复
    Be careful removing the two screw plugs by the 30 pin connector. They are easy to scratch. I couldn’t get the plugs out with my tool kit and finally removed them with the point of an exacto knife.
    Behind the two plugs are sticky pads that will need to be handled carefully and saved for reassembly.
    If you order a tool kit online, be sure it has a Y1 tri-wing screwdriver. The one in my kit was not Y1 and would not remove the screws.
    I had to order a new screwdriver.
    George Tomlinson - 回复
    I don't see any screws I have a galaxy tab 4
    Tammylynn Gmarter - 回复
    if your model doesn’t have these screws, it’s probably ok to just skip this step. at least that’s what i did on model gt-p7500, and that repair was successful (battery replacement). Janine, a friend asked me to fix his Tab where that had happened when he tried to replace the battery himself… i just took out the 3 big cables over the battery, and re-inserted them, and that fixed the problem. you should try that if you haven’t already..
    divinity76 - 回复
    Mine doesn't have screws so what do I do now?
    katrinawisner - 回复
    charging samsung battery dabka ilaaliyo
    Maxamed Xuseen - 回复
  2. 三星Galaxy Tab 10.1吋主板更换: 步骤 2 中的图像 1,3 三星Galaxy Tab 10.1吋主板更换: 步骤 2 中的图像 2,3 三星Galaxy Tab 10.1吋主板更换: 步骤 2 中的图像 3,3
    • 从左侧的中间开始,并在后面板和前面板组件之间插入塑料撬棒。
    • 仔细地沿着左上角和上边缘移动塑料打开撬棒,将后面板远离设备的其余部分。
    • 沿着您已经打开的一边放置开口,以使后面板与设备的其余部分分离。
    • 一定要小心操作,撬得太大力可能会弄碎屏幕。
  3. 三星Galaxy Tab 10.1吋主板更换: 步骤 3 中的图像 1,3 三星Galaxy Tab 10.1吋主板更换: 步骤 3 中的图像 2,3 三星Galaxy Tab 10.1吋主板更换: 步骤 3 中的图像 3,3
    • 使用塑料撬棒,继续沿右下边缘小心地移动,然后从后面板提起屏幕。
  4. 三星Galaxy Tab 10.1吋主板更换, 电池: 步骤 4 中的图像 1,3 三星Galaxy Tab 10.1吋主板更换, 电池: 步骤 4 中的图像 2,3 三星Galaxy Tab 10.1吋主板更换, 电池: 步骤 4 中的图像 3,3
    • 翻转固定三条大型带状电缆的ZIF连接器上的固定翼。
    Looking at the ZIF connectors in step 4....mine isn't charging. I suspect the problem lies in the jack for the USB/power cable. Would I be correct in thinking it's a matter of following to this point, then replacing the internal cable?
    gzapiec - 回复
    I took the cable all the way off and can't get on what to
    I have sound but no pictures/screen what did I do wrong what should I check?
    Rodney perini - 回复
    If you don't have a picture on the screen, it could be caused by an issue with the electrical connectivity on one or other of the power/ data cables. Carefully unplug, clean and re-seat each of the cables, ensure if you use cotton buds, that you use a high powered magnifying glass to check for any flecks left behind….
    Re-seat the. Cables and try again.
    I hope this works for you Rod…
    By the way, to confirm a backlight issue, get a high power torch, or your mobile phone torch will do. Now shine this closely at an angle to the screen. You might see a faint non-illuminated screen!
    Phillip Gamble - 回复
    Unplug the battery first else you may short the connections
    Macro Man - 回复
  5. 三星Galaxy Tab 10.1吋主板更换: 步骤 5 中的图像 1,2 三星Galaxy Tab 10.1吋主板更换: 步骤 5 中的图像 2,2
    • 取出电池周围的十个3毫米十字槽十字螺丝。
  6. 三星Galaxy Tab 10.1吋主板更换: 步骤 6 中的图像 1,3 三星Galaxy Tab 10.1吋主板更换: 步骤 6 中的图像 2,3 三星Galaxy Tab 10.1吋主板更换: 步骤 6 中的图像 3,3
    • 用手指或喷嘴将电池的边缘提起。
    • 按住主板,同时轻轻抬起电池,取出电池。
    Very simple, clever and effective presentation of opening rear cover.Thanks very much for simplicity. The way presented is user friendly.
    Video presentation is mostly in dark ambient, it is useless. Once moore thank you very much.
    Ljubo Baricevic - 回复
    The battery connector lifts up, not back. A plastic tool lifting under the five wires from the battery right at the base of the connector helps.
    Peter Mui - 回复
    then what where do you buy a battery
    Janie montemayor - 回复
    ok after its all apart where do i buy the battery
    @janiemontemayor Sorry about that—the link for the replacement battery was out of date. It's fixed now! Try the link at the top of this guide.
    Jeff Suovanen -
    Welches Tablet hast du denn da? Mein 10.1 hat keine Schrauben an der Ladebuchse
    Anja Mickenbecker - 回复
  7. 三星Galaxy Tab 10.1吋主板更换, 音量和电源按钮: 步骤 7 中的图像 1,1
    • 用手指按住主板,并使用喷嘴轻轻撬开音量键和电源键的连接。
    Hi anyone can tell me where to find this button, please, thx
    Johnny Khoo - 回复
  8. 三星Galaxy Tab 10.1吋主板更换, 闪光灯和后置摄像头连接: 步骤 8 中的图像 1,2 三星Galaxy Tab 10.1吋主板更换, 闪光灯和后置摄像头连接: 步骤 8 中的图像 2,2
    • 使用喷嘴的平端,从主板上拔下黑色闪光灯电缆连接器。
    • 断开白色背面相机连接器。
  9. 三星Galaxy Tab 10.1吋主板更换, 前置摄像头,Micro SD卡/耳机连接: 步骤 9 中的图像 1,2 三星Galaxy Tab 10.1吋主板更换, 前置摄像头,Micro SD卡/耳机连接: 步骤 9 中的图像 2,2
    • 使用喷头的平头端断开橙色前置摄像头连接器。
    • 从主板上的插座上拔下蓝色的Micro SD卡/耳机插孔连接器。
  10. 三星Galaxy Tab 10.1吋主板更换, 扬声器和天线连接: 步骤 10 中的图像 1,3 三星Galaxy Tab 10.1吋主板更换, 扬声器和天线连接: 步骤 10 中的图像 2,3 三星Galaxy Tab 10.1吋主板更换, 扬声器和天线连接: 步骤 10 中的图像 3,3
    • 使用喷嘴的平端,断开左右扬声器的橙色扬声器连接器。
  11. 三星Galaxy Tab 10.1吋主板更换, 主板拆卸: 步骤 11 中的图像 1,2 三星Galaxy Tab 10.1吋主板更换, 主板拆卸: 步骤 11 中的图像 2,2
    • 从底部边缘抬起,轻轻取下主板。
结论
要重新组装您的设备,请按照相反的顺序执行这些说明。
18等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Davie Sy
于09/30/13注册
1,430 声望
创作了4篇指南
团队
Cal Poly, Team 13-5, Forte Fall 2013 Cal Poly, Team 13-5, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G5
5 名成员
创作了17篇指南
5指南评论
Comment passe t'on de l'étape 6 à 7 ? (plastique gris qui fait le tour)
Sebastien Mlakar - 回复
My 10.1 tablet switches on but the only thing showing on the screen is the “Samsung Galaxy 10.1” logo.
If the on/off button is held down for 20 seconds or so the screen goes blank for a few seconds then the logo reappears but nothing else happens. This logo only disappears when the battery is fully discharged.
After re-charging the battery the whole process is repeated
Any suggestions as to the problem
Jim
Jim Smith - 回复
I'm having the same issue
PBRECHEISEN5567 -
have anyone found a solution?
Shaun Smith - 回复
What if I don't have screws on the outside of tablet?
Stacy Moseley - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 41
总计 47,424
