跳转到主内容
更换 Apple Watch Series 2 的屏幕
你所需要的
视频概述
  1. 更换 Apple Watch Series 2 的屏幕, 打开显示屏: 步骤 1 中的图像 1,1
    • 准备iOpener,并加热显示屏以软化粘合剂,将其固定到位。
    I have heated up the iOpener to 165 degrees and left it on for more than a minute. No way I can lift the screen off with the exact knife. Tried different angles in various places, but no go. I also used a hair dryer un til the watch screen was too hot to touch and even tried a very hard cutting tool blade and also no go. Could n ever get the blade under the face I applied enough force where I could see that the blade left small marks, not very big, but could never get anything to move or lift. What am I doing wrong? I spent 47 years at a global computer company and I am used to taking apart small things and applying force when required. I don’t know what I am doing wrong. Please help me.
    Rafael Blanco - 回复
    Getting the initial gap is not easy. Maybe a playing card could work its way in the tiny gap and cut some adhesive. After that there might be some success with an exacto knife. Or you want to try a piece of aluminum foil (folded for more rigidity) for cutting the adhesive. Be aware of the force touch gasket and that it might get damaged during that procedure.
    Tobias Isakeit -
    I finally used a hot air gun set to 150 deg. C heating up the edges by slowly spinning the watch around before the technique worked. Difficult is the level noted and it’s correct. Finally worked and watch perfectly functioning.
    Chris Giavotto - 回复
    I used a heat gun, too. I was worried after reading comments that it would burn up the LCD, so I heated it a little bit at a time, rotating it like you did, and checking to see if I could get my knife under it. I must have hit one of the buttons because it did turn on, but that did reassure me that the display was okay.
    It's open. Now that the watch and I have had a few minutes to cool down, I'm ready for the next step. Not as difficult as I thought it could be. Tomorrow, I'll be replacing the battery in an iPod Touch 6th Gen.
    bester -
    I had to heat the iOpener 2 times and leave it on top of the watch for 10 minutes.
    Axel Trujillo - 回复
  2. 更换 Apple Watch Series 2 的屏幕: 步骤 2 中的图像 1,3 更换 Apple Watch Series 2 的屏幕: 步骤 2 中的图像 2,3 更换 Apple Watch Series 2 的屏幕: 步骤 2 中的图像 3,3
    • 始终保持手指完全远离刀。 千万不要施加太大的压力,因为这可能会导致刀滑动并切割或损坏手表。
    • 仅将刀片的细边插入间隙,然后朝您的方向倾斜刀片以加宽间隙,并将显示屏略微抬起。
    • 将弯曲刀片的边缘放入显示器和外壳之间的薄间隙中。 从显示屏的短边开始,最靠近圆形圈。
    • 不要将刀插入1/16英寸(约2毫米)。
    It’s difficult to grip case in a way that keeps fingers safe from the blade but doesn’t hit the side buttons and turn the device on!
    If it’s a struggle to get the display to release, warm case for a few more minutes.
    Kyle Powderly - 回复
    I have tried so may times to get the display to release but nothing works. Should have bought a new watch LOL. Kept the iOpener on 2 times for 10 minutes and it still won't open. There must be a better way.
    Susan E. White - 回复
    Hi Susan,
    if you're struggling to get the adhesive loose enough a hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    Dominik Schnabelrauch -
  3. 更换 Apple Watch Series 2 的屏幕: 步骤 3 中的图像 1,2 更换 Apple Watch Series 2 的屏幕: 步骤 3 中的图像 2,2
    • 一旦使用刀片打开了小间隙,请移除刀片并将打开工具的较薄边缘插入间隙中。
    • 在此插入翻译将开口工具推入间隙,用拇指作为支点,将显示屏再打开一点。
    • 现在不要试图完全分离显示屏。 Force Touch垫圈可能会粘在显示器或机身上,如果用力过猛,可能会被撕裂。
  4. 更换 Apple Watch Series 2 的屏幕: 步骤 4 中的图像 1,3 更换 Apple Watch Series 2 的屏幕: 步骤 4 中的图像 2,3 更换 Apple Watch Series 2 的屏幕: 步骤 4 中的图像 3,3
    • 在显示屏下方插入一个开口拨片,小心地将Force Touch垫圈与显示屏分开。
    • 确保您找对了位置。 如果在抬起显示屏时把Force Touch垫片分离了,或者您将垫圈层分开,则还需要更换Force Touch垫圈本身。
    • 在显示屏周围滑动拨片以分离Force Touch垫圈和显示屏之间的粘合剂。
    • 不要将开口拨片插入深度超过1/16英寸(~2 mm)。
  5. 更换 Apple Watch Series 2 的屏幕: 步骤 5 中的图像 1,3 更换 Apple Watch Series 2 的屏幕: 步骤 5 中的图像 2,3 更换 Apple Watch Series 2 的屏幕: 步骤 5 中的图像 3,3
    • 为避免损坏显示屏电缆,请勿完全打开显示屏。
    • 将显示屏打开约45°角,然后用镊子剥去显示屏和Force Touch垫圈之间的粘合剂。
    • 将粘合剂穿过显示器电缆的周围和后面,使其完全脱落,然后向下按压垫圈以重新粘附到盒子上。
    • 如果Force Touch垫圈本身松动且不会向下弯曲,则应更换垫圈下方和垫圈与显示屏之间的粘合剂。
  6. 更换 Apple Watch Series 2 的屏幕, 断开电池: 步骤 6 中的图像 1,2 更换 Apple Watch Series 2 的屏幕, 断开电池: 步骤 6 中的图像 2,2
    • 卸下固定电池连接器的金属罩子的螺丝钉。
    • 用镊子取下罩子。
  7. 更换 Apple Watch Series 2 的屏幕: 步骤 7 中的图像 1,2 更换 Apple Watch Series 2 的屏幕: 步骤 7 中的图像 2,2
    • 用撬棒一角竖直向上撬动电池连接器断开电池。
    • 轻轻地让连接器向上弯,以防意外接触。
  8. 更换 Apple Watch Series 2 的屏幕, 屏幕: 步骤 8 中的图像 1,2 更换 Apple Watch Series 2 的屏幕, 屏幕: 步骤 8 中的图像 2,2
    • 用一把镊子剥掉覆盖显示屏电缆连接器的胶带。
    • 从磁带的右下角开始,小心地朝中间的接口方向前进。
    • 这个胶带可能会很粘,所以请小心不要拉得太用力导致底下的电缆被损坏。如果需要的话,可以加一点热或者使用一些异丙醇来使胶带软化
    Das Klebeband muss gar nicht vollständig abgelöst werden. Es reicht aus, die Stecker freizulegen. So hat man beim Wiederzusammensetzen das Klebeband wieder in der optimalen Position und auch nicht das Risiko, die leitende Folie zu verletzen.
    BMJ - 回复
    BMJ's comment translated by translate dot google dot com:
    "The adhesive tape does not need to be completely removed. It is enough to expose the connectors. This means that when you put it back together you have the adhesive tape in the optimal position again and there is no risk of damaging the conductive film."
    Robert - 回复
  9. 更换 Apple Watch Series 2 的屏幕: 步骤 9 中的图像 1,3 更换 Apple Watch Series 2 的屏幕: 步骤 9 中的图像 2,3 更换 Apple Watch Series 2 的屏幕: 步骤 9 中的图像 3,3
    • 在最左边的接口上是一块导电箔,在取下胶带时可能会撕裂。
    • 如果它撕裂,从左下方抓住它以完全移除它。这样的话,底下对应的一个导电箔(显示器上的)将不会被损毁。
    How important is the conductive tape?
    John Ellis - 回复
  10. 更换 Apple Watch Series 2 的屏幕: 步骤 10 中的图像 1,3 更换 Apple Watch Series 2 的屏幕: 步骤 10 中的图像 2,3 更换 Apple Watch Series 2 的屏幕: 步骤 10 中的图像 3,3
    • 小心地使用撬挖工具或者一个干净的指甲通过撬开电缆正对着的接口上的三个小黑翻板锁来打开三个ZIF连接器上的第一个。
    Ir is viral to lift the small black flap or you ruin the entire process here, I lost everythign here...the first one stuck and the entire connector discintigrated on me, not my first rodeo, but lost the entire project.
    Lisa Russell - 回复
  11. 更换 Apple Watch Series 2 的屏幕: 步骤 11 中的图像 1,3 更换 Apple Watch Series 2 的屏幕: 步骤 11 中的图像 2,3 更换 Apple Watch Series 2 的屏幕: 步骤 11 中的图像 3,3
    • 在剩下的两个连接器上撬开翻板锁
    • 替换的屏幕是要安装在关上的翻板锁上的。所以在重新组装的时候,插入电缆之前,确保翻板锁是开的,否则你将损坏你的手表。
  12. 更换 Apple Watch Series 2 的屏幕: 步骤 12 中的图像 1,3 更换 Apple Watch Series 2 的屏幕: 步骤 12 中的图像 2,3 更换 Apple Watch Series 2 的屏幕: 步骤 12 中的图像 3,3
    • 使用一把镊子轻轻拉出显示器的柔性电缆来断开它们。
    • 如果电缆卡住了,在拉它们出来时尝试小心地左右摇动电缆。
  13. 更换 Apple Watch Series 2 的屏幕: 步骤 13 中的图像 1,1
    • 取下显示屏。
    • 详细的重新组装指南,包括更换Force Touch垫圈和周边粘合剂,请参照本指南
    hi
    how are you
    Please answer me quickly
    i have a apple watch 3 and broken lcd
    can i replace this lcd with a lost apple watch lcd?
    Does it work?
    I've heard that Apple does not allow this and ban the device!!!!
    Hossean Dad - 回复
结论
请按Apple Watch Series 2 更换粘合剂
的第10步开始操作来重新组装设备并完成修理。为了达到最好的效果,请不要连接屏幕直到第17步。
99等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,598 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
18条评论
Job done….With a smashed screen remember to apply clear scotch tape to hold the screen together. Continue to heat the remaining stuck shards when the main bulk of the glass comes out. Pick them out carefully, and not to raise the gasket. Use a strong magnifying glass. the ifixit heat gel pack and tweezers helped me. Ensure that all tiny bits of glass have been removed form the body. Just turn it upside down, give a couple of gentle taps with something plastic. Pick out if necessary, taking care around the components. For a smashed screen, needs a good hour or more.
pep073 - 回复
Congratulations on the successful repair. And thanks for your comment and additional hints.
Tobias Isakeit -
This one was tough…and I’ve been doing various repair for years. Thank you iFixIt for top notch tutorials and instructions (and the progressive photos). I had a broken display and an iCloud locked watch for parts. Getting the display off the broken iWatch was easy…getting the replacement/good display off the other iWatch was very difficult. I keep at it and eventually it released, but I think I chipped the display edges slightly. If I have to do this one again, I may think twice. I’d say use plenty of heat. I used the iRemover, which helped a lot, it gets plenty hot and holds the heat for job. Once you’re inside, you’ll need that every so special 000 tri-lobe bit for the battery (for this I bought the iFixIt Pro toolkit…worth it to have a solidly made set of disassembly tools). I don’t think it’s worth breaking down the iWatch for repairs much further than the display or battery. The water resistant seal is compromised enough as it is with the display removal.
Erica Rogers - 回复
Just wondering are the ion x glass and sapphire crystal screens interchangeable because I have a broken series 2 aluminum case and it comes with the ion x glass but I want to get the sapphire crystal glass instead to make it stronger
Jacob Gerhart - 回复
Displays of the same Series, model and size should be compatible.
Tobias Isakeit -
Just noticed that my reply might come across a little vague.
Same Series hopefully makes sense (some swapped Series 3 onto Series 2 and vice versa which lead to the displays getting warmen than usually).
Same model means LTE or GPS which is probably irrelevant since the Series 2 does not have LTE.
And same size is hopefully a no-brainer ;)
So to summarize, yes, Sapphire display of the same watch should work instead of an ion-x.
Please let me know if it won’t work.
Tobias Isakeit -
I have an Apple Watch series 2 with wOS 5.2 and an iPhone 8 with iOS 12.3.1
After installing a new aftermarket display I’ve connected the watch with my phone with out any trouble. But I was not able to update to wOS 5.2.1 Also I added my credit card to wallet on the phone after the repair job, but was not able to add it to the watch.
So I tried to completely reset the watch and try it all again but now I am not able to connect it to my iPhone at all.
I have another Apple Watch 2 that has wOS 5.2.1 and a weak battery and a Digital Crown with ghosting behaviour but still the original display. Might it work to install the original display on the other watch to resolve the connection problems?
Has anybody made similar experiences and any idea/advice what I might do?
Kristian Heitkamp - 回复
I figured out, why the Apple Watch did not pair even though wOS 5 was installed.
I opened it and figured out, that the GPS modules connector was loose and just fell of the display, when I touched the cable.
Connecting the (broken) display from another watch made it pair and upgrade again but still I am not able to add Apple Pay. I guess that it recognises the GPS module and since it is wOS 5 it works even though it is not the original GPS module. But I think, because it is not properly connected to all three cables of the display the GPS maybe is not able to fix a location which disables the Apple Pay function out of security or licensing reasons.
Now I think this experiment confirms, that any display will work under wOS 5.2 (maybe even wOS 5), even if it is the display from another Apple Watch.
Hat super geklappt,
zwar wurde ich während der arbeit vom Hund erschrocken und habe somit den Force Touch Sensor etwas beschädigt; habe mich aber dazu entschieden einfach ohne ihn zu Leben. :)
Wirklich genutzt habe ich ihn nur für das löschen aller Benachrichtigungen.
Patrick - 回复
I’m curious about the following statement.
Continue from Step 10 of our Force Touch Sensor guide to re-seal your watch and complete your repair.For best results, don’t connect your new display until after Step 17.”
where is step 17? My up to date chrome browser is only showing 15 steps.
Other than that, I’m excited to fix my watch.
alexander perry - 回复
Hi alexander, that is step 17 in the Force Touch Gasket guide, not in this guide (which has only 15 steps). The Force Touch Gasket guide shows the steps with the display attached, but since you took it off during this guide you’re much better off attaching it after step 17. Have a successful repair
Tobias Isakeit -
Do i need to change the front screen with the lcd screen or can i change only the glass?
Cecilie Falch - 回复
Hi Cecilie, though it is possible to only change the glass, I’d not recommend it. You might feel the same after watching this video (it’s a Series 4 but basically the same procedure for the glass)—or you feel empowered by it and will try that procedure (with success hopefully): https://www.youtube.com/watch?v=PZYWzsB_...
Tobias Isakeit -
Si po montare un display serie 2 sul in serie 3? Grazie
vale rosi - 回复
it would be the same display of series 2 to series 3?
Abraham Mojica E. - 回复
Ich konnte vor dem Displaytausch mein ApplePay nicht mehr deaktivieren. Nun lässt sich mit dem neune Display keine ApplePay-Karte mehr hinzufügen. Gibt es hierzu eine Lösung?
Christian Ritter - 回复
Hello, good afternoon, if one applewach is locked, does the display still work for another applewach?
Polo - 回复
Yes, swapping the display from a locked watch to an unlocked watch should work. Only thing that could not work is the NFC / Apple Pay since the chip on the back of the display carries the NFC information and needs to be transferred.
Tobias Isakeit -
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 119
过去 30 天: 579
总计 120,503
