跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
screen blacks out but still works
I'm have the same issuse a lot of people are having with the older macbook now. screen goes black. you can still see image slightly and pushing the display brightness buttons do nothing. if i close the lid almost all the way the screen comes back, but if i open it all the way again in goes black again(sometimes) other times it works just fine. using an external display works fine too. does anyone now what exactly is going on? inverter cable, inverter, or something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
First hook it up to an external monitor. The fact that it comes on when closing the lid indicates a severed inverter cable. I would not get a used cable to repair this, get a new one, otherwise your problem may return quickly. It's Apple part number 922-7612 http://www.welovemacs.com/9227612.html
这个答案有帮助吗?
得分 3
4条评论:
完成的
I have the external screen hooked up as a secondary screen. when the lid is up it still functions as so. with the lid closed it will favor the external. however if I close the lid 3/4 of the way the screen comes back on(only at that angle) and doesn't shut off. it has never flickered. if I fuss with it enough I an get the lid all the way open with the screen working. eventually it goes black sometimes it stays on just fine
完成的
Hi Mr Mayer
On boot up the apple logo and the status bas show briefly very faint, then brighten, fade and then all goes black
Somewhere I read there is a start up screen driver then an apple one
the external screen works well,
System - display still shows lcd working etc
any pointers,
is there any diagnostics I can run ?
完成的
Do exactly what I said in my original answer. This appears to be an inverter issue.
完成的
添加一条评论
I have this same problem. I watched this video and this guy has seemed to have solved it!
https://www.youtube.com/watch?v=wh6jYrHh...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
crooney66 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 10
总计 913
