跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Has anybody tried heat to loosen battery glue?
The MBP Retina teardown uses brute force on the battery. Have you tried applying heat?
I would apply a heat-shrink style heat gun to the metal opposite whatever is stuck, right at the location where I'm prying. Do not directly heat the battery.
I haven't got an MBP Retina, but I've noticed the adhesives used in the old MBP respond to heat very well.
FWIW. Try this before solvent, which was suggested in another query. (Then try Goo-Gone, if you can avoid contaminating other components.)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
I would be very cautious suggesting the use of heat on these batteries, you risk fire. explosion, noxious fumes serious personal/property injury!! Apple's technicians have been told that the battery is not a replaceable part. their solution is to replace the top case assembly, to which the battery is fixed. IMnsHO encouraging a DIY to attempt this proces would be on the order of encouraging an amateur to work on a CRT--irresponsible and unprofessional.
这个答案有帮助吗?
得分 2
3条评论:
The idea is to heat the glue, not the battery. These glues usually soften at a relatively low temperature: heat-shrink gun, not paint stripper!
If it works, it's better than a putty knife, which is the solution already offered here. If you short one of these batteries it gets plenty hot all by itself. Certainly it is safest to replace the whole assembly; only a DIY will try otherwise, so it's as well the DIYs know what's involved first.
完成的
Methylated spirits is also an easy way to manoeuvre the battery out just use a q tip and gentlly loosen it out using a dropper is quite helpful also
完成的
I just replaced the battery pack on my MacBook Pro (Retina, Mid 2012) 15" and I looked at Youtube for help... One guy was using canned air (Dust-Off) with the can upside down so the cold liquid would get underneath the battery -- making the adhesive brittle, and then snap! The battery releases. http://www.youtube.com/watch?v=DPqrmt-Ic... Also another trick is instead of using the iFixit adhesive remover which I believe is acetone I used tried and true "Carpel-O-Peel" adhesive remover -- far less noxious. and worked even better at removing the residue AFTER I had removed the battery pack with a small narrow spatula/cake knife/putty knife. I also used the string method on a couple of batteries -- that works too especially with the cold dust-off liquid. Instead of string I found that edge trimmer cord (RYOBI 0.80" twisted bulk line from Home Depot AC04138 and AC04139) was even stronger but I had to get the battery started with a spatula to fit the monofilament underneath and around the battery.
完成的
添加一条评论
最有帮助的答案
Try this
http://www.instructables.com/id/Easily-R...
这个答案有帮助吗?
得分 5
3条评论:
Wow, cool! Thank you, this is very helpful!
完成的
A Video with isopropyl alcohol directly with the the macbook:
https://www.youtube.com/watch?v=pLhHSIej...
完成的
the problem with solvents is .. well they are "solvents" .. you need to be very very careful!!
完成的
添加一条评论
Just did a trackpad on a 2012. The battery glue was a nightmare. I used alcohol. It disolved the glue pretty quick. Still you need to take time and patience to do it so it doesn't tear or break anything else.
这个答案有帮助吗?
得分 0
添加一条评论
Best kept secret and works like a charm! I use good ole WD-40 poured into a syringe with a plastic tip. DON’T USE A METAL one to avoid puncturing the battery. Run a line the liquid near the longest edge and orient the battery so that gravity can move it under the battery. From the other side apply some heat just until it feels hot to the touch. The aluminum will dissipate the heat through the glue and help wick the WD-40. Keep running WD-40 until it stops wicking with some more heat if it cooled of. Wait for about 5 minutes, give it some more heat.
You can now start the battery detachment procedure. The battery should come off very easily with little pressure. If you feel any resistance, run some more WD-40. When removed, make sure you clean up all residual WD-40 with acetone or alcohol from all areas. WD-40 is a lubricant and a tiny bit of it should hurt anything, but it will prevent any adhesion.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marcus Brooks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 10,418
