Is this a problem
I’m replacing a HDMI on an Xbox one S and 2 pads look to be bridged I’ve tried to go over it with desoldering wick but it doesn’t seem to change I’m unsure if the solder mask has come away is there a way to fix this
Hi!
The last pin is definitely damaged and got seperated from the trace there.
You need to unbridge the pin first, then try to reconnect it to the trace. You can carefully scratch there to reveal the copper. Then you can connect them to together.
Hopefully that will do the job! Not gonna lie, it won’t be easy.
Please let me know how that goes!
这个答案有帮助吗?
过去 24 小时: 25
过去 7 天: 25
过去 30 天: 25
总计 25
