My pc didn't on
My power adapter is ok but my pc is not working
@aniketmajhi start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove/Disconnect the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. I know you've said that the "power adapter is ok" but you did not tell us how you've checked that. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Use the HP ProDesk 400 G4 Small Form Factor (SFF) Maintenance And Service Guide to work on your computer.
It is also possible that this is a bad RAM module. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Lt us know what you find out.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 30
总计 30
