跳转到主内容
加入维修社区 - 创建账户
苹果 2021 年的顶级智能手机。iPhone 13 Pro Max 于 9 月 24 日发布,配备 6.7 英寸 ProMotion OLED 显示屏、全新的后置三摄系统以及 5G 连接功能。它是 iPhone 12 Pro Max 的继任者。
Cellular front end diagnostic
How do you guys go about diagnosing Cellular front end issues on iPhone? I’ve replaced the charging flex on two iPhones recently and they end up failing the Apple diagnostics after. Cellular appears to be fine and working. The replacement flex is OEM pull. It appears to be working correctly as it all passed the diagnostic except for the Cellular test. Is there anything specific I should look for? I cleaned and checked all the grounding contact points on the screen/frame and the pins themselves and they looked fine. The only repair this 13 Pro Max had was a charging port replacement. I only removed the lower components needed to do the replacement so Im not really sure what went wrong.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Molded within the case are the antennas which are accessed by the cellular front-end logic via screws and bus bars. Make sure you have a good electrical connection between the Antenna point and the logic board. Any corrosion, tarnish or physical damage can prevent good connection to your cellular provider.
To see the signal strength I just use the codes as listed here All iPhone Secret Codes
*#3001#12345#*
Use a second phone accessing the same carriers network at the same location to gage if your connection is good.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CAB 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 42
总计 42
