跳转到主内容
加入维修社区 - 创建账户
2023 年 9 月 22 日发布的 iPhone 15 的维修、拆卸和故障排除信息。它配备 6.1 英寸 OLED 显示屏、4800 万像素双摄像头系统和 USB-C 接口。
Snapped back flex cable
While removing the back glass of the iphone 15, I forgot about the flex cable, moved the back glass up, and snapped the flex cable connecting the back glass and the phone.
Is my only option here to purchase a wireless charging assembly? Or can I get the flex cable alone?
Replace a damaged or malfunctioning internal inductive charging coil in an iPhone 15.图片
产品
iPhone 15 Wireless Charging Antenna Assembly
$20.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Actually, yes, you can get just the flex cable if you're confident in your soldering skills to make four small solder joints. I'd describe myself as slightly better than average electronics soldering skills, and this is something I would attempt; in fact, I've done a similar repair on an iPhone 11 Pro.
Here's one flex cable I located; there may be more if you continue to search on a phrase like "iphone 15 flex cable for wireless charging replacement".
1Pcs Wireless Charging NFC Coil Flash Flex Cable For iPhone 15 16 Plus 16 15 Pro Max Charger Panel Sticker WPC Pad Tape Parts - AliExpress 509
However, if cost is a factor, the full coil plus cable is only about $1 USD more than the cable alone. If it was me, the main consideration would be whether I wanted to go to the work of removing and replacing the charging coil; it looks like the new coil I linked to does contain the magnets.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tamaam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 28
