跳转到主内容
加入维修社区 - 创建账户
Razer Blade(2018 款)是一款 2018 年 5 月发布的 15.6 英寸游戏笔记本电脑。
Doesn't turn on
I bought a used laptop FB Marketplace and it worked for 3 days and all of a sudden it doesn't turn on. I thought it was the battery so I removed it and plug in the charger but still doesn't turn on. On top of that I noticed that when I press and hold the power button. I see the green power light flicker just once. Can anyone help me out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
When you say you it "worked for 3 days" do that mean you've only had the laptop for 3 days? If yes you should be able to return the laptop.
由完成的
Sorry for not giving all the details but it is a used laptop in FB martket
由完成的
@andrewortiz
Does the laptop indicate that the battery is being charged when the charger is connected?
由完成的
添加一条评论
2个答案
That single flicker suggests the laptop is getting some power but failing to start. Try a hard reset with the charger disconnected, then reconnect the charger and test again. If it still only flickers once, I’d suspect the charger/DC-in circuit, motherboard power circuitry, or a shorted component rather than the battery.
这个答案有帮助吗?
得分 0
添加一条评论
@andrewortiz the single green flicker means the charging controller is attempting to turn the laptop on but immediately detects a short circuit or power rail failure and shuts down to protect the board. First, disconnect the main battery and the charger. Locate the small coin-cell CMOS battery on the motherboard, unplug it for about ten minutes to completely drain the volatile memory. After that plug only the charger back in to see if a corrupted BIOS was blocking the boot sequence.
If the CMOS reset fails, a shorted peripheral might be the issue. Strip the board down to the bare minimum by removing the RAM sticks, the NVMe SSD, and the Wi-Fi card. Plug the charger in and try to power it on. If the laptop stays powered on and the fans spin, reinstall the components one by one to identify which one is shortening out your system.
If the board still only flickers with all peripherals removed, you have a short circuit on the logic board itself. You would have to check for a short to ground on the main 19V rail and the primary 3.3V and 5V inductors. A blown MOSFET or shorted capacitor in the GPU or CPU voltage regulation rails is common and could be causing your issues.
We will need to see your motherboard nad need to know the exact model for it. That way we can check for schematics to help you out further if needed. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Ortiz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 56
总计 80
