跳转到主内容
加入维修社区 - 创建账户
Steam Deck OLED 的维修、拆卸和故障排除信息, Steam Deck OLED 是 Valve 制造的掌上游戏机的 2023 年新版。于 2023 年 11 月 16 日发布。型号标识为 1030。
Left joystick having drift/input problem
I had a tiny bit of water spill on steam deck turned it off immediately for 4 days turned it on as I was told and everything is working fine except the left joystick keeps going left but when I switch to desktop mode and use the keyboard it goes up and down fine even pushing down on it to turn on and off caps lock works fine just can’t go left or right is there a way to fix the joystick or anything I’m not trying to buy a whole new steam deck I just bought this one not even a full year ago
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
First, open it up and check for corossion inside. If you find any, clean it with isopropyl alcohol. For the left stick, clean it with isopropyl alcohol anyway and see if that fixes it.
If not, then replace the left joystick and see if that will fix it!
Guide: Steam Deck OLED 拇指摇杆更换
Please let us know how it goes!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lamar Stapleton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 89
