跳转到主内容
加入维修社区 - 创建账户
{A1989 / EMC3214}—发布于 2018 年 7 月,这款 13 英寸 MacBook Pro 配备了四核 i5 和 i7 处理器以及 Intel Iris Plus 集成显卡。
Battery or logic board
As both the logic board and battery will be replace which one should be removed first; Should I remove the battery or the logic board first?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First off, unless you already have the parts at hand cheaply this is not the most economical way to get a working system. This series had its issues as Apple was struggling with the Butterfly Keyboard and Intel's chips ran quite hot! I frankly would get a used M1 system which would be the better investment.
If I haven't swayed you then I would remove the logic board first following this guide MacBook Pro 13" Touch Bar 2018 逻辑板更换 don't forget the TouchID power button need to stay with the logic board as is married to it! Also be very careful taking it out as the ribbon cable can be damaged quite easily. I use a few pieces of colored electricians tape to mark the board and its button so I don't get things confused while working on the system.
To remove the battery follow this guide jumping over the logic board stuff which you've already have done 2018年款带 Touch Bar 的13寸 MacBook Pro 电池更换 picking up at Step 19 removing the Trackpad. Apple uses a very strong adhesive and one often damages the battery in the process of removing it. The construction of the battery requires the many layers be held at a distance internally. Bending and stressing the battery trying to remove it damages the internal structure which could fail with smoke and even fire when charged. Best to use a fresh battery not reuse!
MacBook Pro 13" Touch Bar 2018 电池图片
指南
难度:
中等
1 - 3 hours
MacBook Pro 13" Touch Bar 2018 逻辑板图片
指南
难度:
困难
3 hours
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
SMC 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 43
总计 43
