跳转到主内容
加入维修社区 - 创建账户
2015款 Nintendo 3DS XL,也被称为 New Nintendo 3DS XL,于 2014 年 10 月 11 日在日本发布,2015 年 2 月 13 日在北美发布。
New 3DS XL constant error screen
I tried to boot up my 3DS after 1-2 years since I last touched it, when plugged into a charger the charging light only shows up after 10-20 minutes of charging, once I turn it on it works for a few minutes and then starts stuttering and finally freezes at the "An error has occurred" screen, holding the power button doesn't turn it off unless I take the battery out. The blue light goes off briefly before coming back on just before the error screen shows up.
So I've swapped the battery, disabled the wifi, removed the SD card but the error screen still shows up after working for 1-2 minutes
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
First: Is the New 3DS XL modded?
Try to get in the recovery menu with doing the following:
turning off the console and holding down L + R + A + D-Pad Up while pressing the power button
Does it work now? If yes, try to update the console and see what happens.
Since it does work for a few minutes, it does sound like software/firmware issues.
Please keep us posted!
这个答案有帮助吗?
得分 2
2条评论:
Hi, after updating and leaving it on for about 1 hour it seems like it worked, It stopped freezing!
Booting into the recovery mode to update was one of the options I had in mind but I was afraid it'd freeze mid-update but I decided to risk it.
Thank you very much!
完成的
Ah glad that it’s solved now! My pleasure :)! Have fun gaming!
完成的
添加一条评论
添加你的答案
Hsia Hz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 43
总计 43
