跳转到主内容
加入维修社区 - 创建账户
Meta Quest 3 于 2023 年 10 月 10 日发布,是 Meta Quest 2 的升级版,在许多方面也是 Meta Quest Pro 的精神续作。
Update and restart loop
I have bought this device used, so I have no warranty.
The device keeps updating and restarting, side load update didn't work because the site said incompatible device or something like that, and factory reset didn't work either (it reseted and still had the loop).
Is there some different manual way to fix that, maybe somehow completely wiping the quest 3's SSD and manually installing the OS?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
It sound like firmware/NAND issues.
It would be very difficult to fix this.
I would check with Meta their support to see what options you have.
Anyway, if you would like to know more about it's NAND, you can follow this: Meta Quest 3 芯片识别
Hopefully Meta does have a solution for you or maybe you can sent it in, so that they can refurb it.
Sorry for the bad news.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aleksandr Muchin 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 27
总计 72
