跳转到主内容
加入维修社区 - 创建账户
Wii 于 2006 年 11 月在北美发布,是任天堂第一款直接支持互联网连接的家用游戏主机,通过 Wii 购物频道 (Wii Shop Channel) 支持在线游戏以及游戏和媒体应用的数字分发。
Drive Lens not moving.
I have the rvl-001 wii and the laser lens doesn't move along the track when I put the disc in. The only answer I found scouring the Internet is bad motor, or something might be jammed with dust or dry grease. I would like help in planning what I should do to identify the problem and how to fix it, because I don't wanna spend money to fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Could be many things.
It's possible that the laser died and is even unable to see the disc, hence it won't move.
It's also possible that the worm motor is broken causing the laser not to move.
And it could be the laser's clamp/bracket.
I always check the laser clamp/bracket first, if it's fine, I replace the laser. Still not working? Then I solder a new worm motor in.
You can check this guide: 任天堂 Wii DVD 光驱激光头更换
Both are easy to replace (worm motor is a little soldering experience required).
I'm afraid you need to spend some money here. Glady, a laser and a worm motor is not that expensive. I would start with a new laser first, they are known to fail.
If you don't want to refurbish the drive, then just replace the whole drive and this should do the job as well. But this will be more expensive
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Adrian Proffer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 66
