跳转到主内容
加入维修社区 - 创建账户
My switch lite wont recognize button presses
So i just did a full shell mod and screen replacement on my switch lite and ever since I have these problems with the buttons,thumbsticks, and touchscreen not registering my presses and movements I replaced the ribbon cable to the right daughter board thinking it was the problem and I have seated and reseated all of the ribbon cables, put two different pairs of joysticks. And its really hit and miss as to when it does it but it wont let me do multiple presses making it to where I cant unlock my device. Does anyone have any ideas what I should do I have all the electronics repair tools needed to fix most things
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Could be a lot of things. Since you have replaced the screen, it could be that the touchscreen was damaged and not registering your input. I would check that one out and also the ribbon cable, in the worst case, you need to replace it for a new one.
I know that there are some really bad shells out there, so it's possible that the shell squished something on the motherboard or broke ribbon cables. Can you let us know which brand you are using? Or is it something from AliExpress?
Are all the buttons stopped working? If yes, it could be motherboard related...
In my opinion, I would transfer it back to the old shell and test again to see if that will work. OR if it's too damaged, buy a broken/donor Switch Lite and get the shell from that one.
Adding pictures could help us > 在已经存在的问题里加入图片
Thanks in advance!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew Derosa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 27
