跳转到主内容
加入维修社区 - 创建账户
Brother HL-L2320D 是一款于 2014 年正式发布的紧凑型黑白激光打印机。它拥有高达每分钟 30 页的高速打印能力,并配备了用于双面文档的自动双面打印功能。该设备通过高速 USB 2.0 接口连接。
Repairing a printer cartridge
During a printing the paper these make some lines some light line some
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
These use the TN-920 - it's basically cloned to death and the 3rd party toner is mature, so you can get a clone TN-920 and save a lot of money. Now Brother does split the drum and toner, so if it continues with a repair (see below) and a replacement toner, you will need an imaging drum.
A lot of the time it's clumpy buildup on the transfer roller on the toner side where the roller which spreads it onto the drum is bad - if you can open it without making a mess, you can sometimes revive it but 8/10 times on Brother toner it is low and needs a refill/replacement, or the toner has bad internal parts where the toner is not being properly distributed. Brothers have a system where they recycle the toner back into the cartridge as they do not store waste toner in the imaging drum, so they have a mechanism which recycles it back into the toner. If the toner feels "full" but you have problems with the print quality a lot of the time it's usually running on regurgitated toner that is dead.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manvik Kayath 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 36
总计 81
