跳转到主内容
加入维修社区 - 创建账户
作为任天堂 Game Boy Advance 的一款升级产品,Game Boy Advance SP 于 2004 年 3 月 23 日在北美地区发布,它采用了方形机身结构和翻盖式设计。
GBA SP not booting
Hello I bought a GBA SP unused online and it won’t boot past the Gameboy screen. The games work in another SP without issue m.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi!
So, for now I advise to clean the pins inside with isopropyl alcohol.
Clean it completely in there, and after this, try again.
If it's still failing, check for damaged pins, if this is the case, you most likely need to replace the port...
But cleaning will be the very first step to see if that will fix it!
Please let me know how that works out :)!
这个答案有帮助吗?
得分 1
添加一条评论
Since the games work normally on another GBA SP, the cartridges are probably not the cause. Because this console only reaches the Game Boy boot screen and never proceeds to load the game, the issue is more likely with the console itself. Common causes include dirty or damaged cartridge slot contacts, poor solder joints on the cartridge connector, or a fault in the motherboard that prevents the game from being read correctly. I would start by thoroughly cleaning the cartridge slot with isopropyl alcohol, then inspect the cartridge connector pins for damage or corrosion. If cleaning doesn't help, the console may need to be opened for further inspection and possible repair of the cartridge slot or motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
Hey Raymone,
I'd try a thorough cleaning of the cartridge slot and game contacts first. Unused consoles can still develop oxidation over time.
Hope it helps :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raymone Massey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 28
总计 123
