跳转到主内容
加入维修社区 - 创建账户
经典 Xbox 无线控制器的第三次修订版于 2020 年 11 月发布,与 Xbox Series X 和 Series S 一起捆绑销售。 该控制器向后兼容以前的 Xbox One 游戏机和 PC。
Potentiometer of joystick replacement problem
Hello,
I replaced the one potentiometer of joystick from a Xbox Series X controller but when trying it I was not able to calibrate it. Changed again and same thing. Does the potentiometer has to have an initial resistance value so I am able to calibrated? Maybe the resistance is very high/low to be able to
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Did you just change the potentiometer only or the whole joystick assembly? Did you try to cslibrate on a PC or an Xbox?
由完成的 分享
I changed only the potentiometer 2 times with no success. The the whole joystick worked. I calibrated it on a emulator in PC because I don't have an actual working Xbox Series X
由完成的 分享
Okay, glad that replacing the joystick worked. Should be OK now! Calibrating on the PC should do it! Have a nice day :)!
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Hi!
Whenever the potentiometer won't fix it, it's advised to replace the joystick assembly completely.
You can follow this guide for that: Xbox Series X/S 无线控制器摇杆更换
After this is done, you can try to calibrate them again.
Please let us know how it goes!
这个答案有帮助吗?
得分 2
4条评论:
Hi,
Thank you very much. I discovered that I was using the same potentiometers I use for PS5 controller and the resistance value is different (PS5 2k3 ohm and Xbox 10k ohm) so that was the issue why I could not calibrate it
由完成的 分享
Ah that explains it!! It’s correct that they are different. Glad that you found out :)! Have a great day!
由完成的 分享
I replaced all my ps4 controller sticks with hall sensor ones. Never had a problem since.
由完成的 分享
Yes that works :)! But this is regarding a Xbox controller. I heard that sometimes it can interfere here with the magnets.
由完成的 分享
添加一条评论
添加你的答案
sascha bauló martínez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 69
总计 227
