跳转到主内容
加入维修社区 - 创建账户
Dell Latitude E6230 商务级笔记本电脑的维修信息与故障排除。该款笔记本电脑配备 12.5 英寸屏幕,于 2012 年 5 月发布。
Where is CMOS battery
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It's buried on these... You need to remove the bottom cover and the lower trim to get to it. https://www.parts-people.com/blog/2018/0...
These use the more common 2 wire Dell battery, whereas the 6220 used the infamous E6X00/10 3 wire batteries which are a lot harder to find. I'm not going to provide links but you can find them on eBay or Amazon readily. Dell uses the same battery today in their modern Latitudes so you might even be able to find an OEM one for a newer model and as long as the polarity is right, you're good to use it. It's the common one Dell has used for a long time: C8KT2
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ayush Bandari 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 25
总计 117
