跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch 是一款掌上游戏机,可以通过底座连接到电视上游玩,也可以随身携带。于 2017 年 3 月 3 日发布。
Volume up Button not working
I'm trying to repair a Nintendo Switch where the volume up (+) button is not responding. Volume down (-) and Power are working fine.
I allready replaced the flex cable.
Same behaviour. Vol + not working, Vol - and Power are working.
Any idea, what could cause this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Hi!
Does it click in well? Do you feel the click? Did you also replaced the rubbers?
If this is the case, you might want to check the connector on the motherboard where it connects to.
If this one is OK, I think it it's the motherboard having issues here.
Did you tried headphones, do they work?
由完成的
@dan0 As I said, I already replaced the Flex cable. But still the same behavior. Tried to click directly on the flex. Connector looks good.
After a bit of googling I am quite sure it is a resistor near the connector.
由完成的
Hi!
Sorry, I meant if you also feel the click on the replacement part. I'm pretty sure it is something on the motherboard. Replacing the resistor would be the next thing to do.
由完成的
@dan0 My replacement part is working well. Do you know which resistor exacly is for the Vol+ Button?
由完成的
Not 100% sure no. Maybe you can check this out: https://gbatemp.net/threads/volume-butto...
There is not a lot to find about it, except that more people are having the exact same issue as you...
由完成的
添加一条评论
1个答案
最有帮助的答案
Thanks @dan0
Your gbatemp link was exactly what I was looking for.
For others as reference:
这个答案有帮助吗?
得分 1
1条评论:
Hi @nintendoc,
That's it :)! We found it.
This is actually really helpful.
That one need to be replaced for sure.
由完成的
添加一条评论
添加你的答案
Nintendoc 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 28
总计 134
