跳转到主内容
加入维修社区 - 创建账户
Charging and Boot Issue
I have a MacBook Pro 13-inch Early 2011. I installed a battery in it, but when I connect the charger, the MagSafe LED turns green, and the MacBook emits a repeating sound approximately every half second. At the same time, a white LED turns on and off repeatedly, and the MacBook does not start.
However, if I disconnect the charger, then press and hold the power button, and while holding it reconnect the charger, then release the power button after a few seconds, the MacBook powers on normally. The problem is that the fan runs at a very high speed, and the green MagSafe LED turns off, although the charger continues to power the MacBook.
I would appreciate it if someone could explain the cause of this issue.
Thank you very much.
Update (06/07/26)
Here is the screenshot as requested.
Please note that the MacBook does have a battery installed 😢
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Install this gem of an App to diagnose what's failing CoconutBattery take a snapshot of the Apps main window and post it here so we can see it.
这个答案有帮助吗?
得分 0
2条评论:
Okay, I will install the application and post the results here.
完成的
Looks like the battery cable isn't fully pressed in or the battery is bad. The other possibility is the SMC chip is not functioning properly but that's only an issue when the logic board has damage.
完成的
添加一条评论
添加你的答案
Ebram Ashraf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 71
总计 106
