跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Can this component be replaced?
So when I was trying to change the analog sticks on my controller I accidently knocked off a component fortunately I have a few motherboards with that component can it be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Yes it can, but requires soldering.
I think it’s a cap.
But since you got the same component on another motherboard, you can just replace it!
Please let us know how that goes!
这个答案有帮助吗?
得分 1
6条评论:
As long as the pads haven’t been pulled off
完成的
Do they look pulled off?
完成的
Hard to see.. can you upload a closer/sharper picture? If the pads are ripped off, you need to repair the solder pad there..
完成的
@christophe89153 try to apply solder to the contacts; if they stick then you're fine & if they don't then you've ripped the pads off. fortunately it's not such a hard fix judging from the pics but it's a little hard to explain
anyway, try to apply solder to the pads and see if they stick first, that'll help a lot.
完成的
Update I put solder on the pads and it looks like it's sticking I've uploaded a photo
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Christopher D 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 123
