跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—在2017年6月上市,这台入门级MacBook Pro保留了它的实体功能键(相对于OLED Touch Bar)。
MacBook battery cable Problem
Hello, I have a 2017 MacBook Pro 13-inch. I recently replaced the screen, and after the repair, the laptop would not power on unless it was connected to a high-wattage charger. It does turn on with the AC adapter, but there is an “X” over the battery icon, and if I unplug the charger, the laptop immediately shuts off.
I suspect the issue may be the battery ribbon cable, which I’ve already ordered, but I wanted to see if anyone else has experienced this or knows what the problem might be.
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Looking at the picture (left side connection) the cable isn't pushed into the connector and latched down.
由完成的 分享
添加一条评论
1个答案
Double check the ribbon cables ZIF connectors as often the compression latches are not properly set so the connection is not making good contact. Review the steps 11 & 12 in the 2017年款带功能键 的13寸 MacBook Pro 电池更换 jump between two images of Step 11 note the lifting of the latch. Make sure the latch is reset pressing it down once the ribbon is squarely in place on both ends.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank I 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 180
