Power button not working it went inside
Power button not working and went inside
Hi, @naraharise87483 I gotchu.
I would say to use some tweezers from a Precision Tweezers Set and try tweezing the power button out.
Also try opening the phone and locating the power button.
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 80
总计 471
What happened to the power button? Went inside where? More info would be useful when trying to get help.
由 someperson 完成的
@somerandomguy_1 If I had to guess, I'd say they mean that the power button is stuck, but yeah, more information would help.
由 Fixer of Stuff 完成的
@fixerofstuff Good point. @naraharise87483, does the button feel like it's jammed by dirt, or did it sink in after a drop? If the button still "clicks", you might want to use Isopropyl alcohol on a Q-tip to clean it; otherwise, the motherboard might have shifted inside the case, causing the button to get stuck underneath the screen.
由 someperson 完成的
