跳转到主内容
加入维修社区 - 创建账户
第四代 Sony PlayStation 5 DualSense 手柄(DualShock 系列的继任者)的维修指南、拆解和故障排除信息。通过型号 CFI-ZCT1W 和主板型号 BDM-040 识别。
What the problem with my x button
So the problem is that I was given a PS5 controller, but when I turned it on, the X button didn’t work, so I couldn’t log into any account. I opened the controller and did some cleaning I found online, but even after that it still didn’t work. I even removed the rubber piece from the PS button and tried to make contact with the X button membrane, but it still didn’t work.
I know it’s not a problem with the rubber because I used the same PS button rubber and touched the circle button membrane, and on the PS5 the controller registered a back action. That’s why I’m asking, because I don’t know if it’s a circuit issue or something with the pins, and I also don’t know how to fix it. I imagine it would require soldering, and I’m not very good at that and don’t have the right tools.
Whoever can help me, I would really appreciate it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
In this case, I would replace the button circuit membrane.
You don’t need to solder for this.
Before you replace it, make sure you got the exact same model as the one that came out.
If you need guides, please let me know!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jahdread Manso 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 40
总计 199
