跳转到主内容
加入维修社区 - 创建账户
How to replace display hinges?
I currently daily drive an HP elitebook 1030 g8, and have recently noticed that he hinges have seriously deteriorated! To the point where several angles beyond 150 degrees will cause the display to fall flat.
I have 2 other systems that may provide me with the parts to solve this issue:
Elitebook 1030 g4
Elitebook 830 g8
If either of these are suitable for a replacement, and you know the method to engage this process please help!
I also do need directions on how to execute this repair because little/no repair material is available online.
Thanks for the support!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi!
To change the hinges, there's two ways.
Either (the more common) is to replace the whole top section with both frame and display. If you would want to do that then HP's maintenance and service manual should suffice, I've linked you to the display disassembly section.
If pdf link breaks, you can find the maintenance and service manual among the manuals and guides on HP's Support page for your device.
The other way is by replacing just the hinges. You would then need to follow the maintenance and service manual to take of the display assembly, and then you would also need to remove the monitor from the frame, which HP EliteBook x360 1030 G3 屏幕更换 shows how to do (similar model). I also found this Youtube video which shows the same thing.
Where to find parts is something we does not always do, as availability and different region means that a market for me likely won't work for you. So my recommendation would be to use your favorite search engine and search for "HP elitebook 1030 g8 hinges / screen assembly / display replacement" in ordered to get localized results that works for you.
Good luck with this,
Cheers
这个答案有帮助吗?
得分 2
5条评论:
Thanks! Ill make sure to try this Asap.
Of course im going to wait until I have the hinges so I will not be able to give feedback immediately.
由完成的 分享
@meekvixen just add the complete document to your answer. Then we don't have to worry about link rot in a few years/months or whenever the OEM decide to retire the link :-) HP EliteBook X360 1030 G8 Maintenance And Service Guide
由完成的 分享
Do you know how I attach a file to the issue? I have the PDF downloaded, but do not know how to attach it
由完成的 分享
@oldturkey03 Wow, thank you! I've never thought about that, I'll keep it mind from now on :) Thanks
由完成的 分享
@briandauber For updating a question with media you can follow this guide: 在已经存在的问题里加入图片
Although, oldturkey has a attached a link to the document, and uploaded the document to the [[Topic:HP Elitebook x360 1030 G8]|device page|.
由完成的 分享
添加一条评论
添加你的答案
BlueSpaceCatno2 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 63
总计 352
