跳转到主内容
加入维修社区 - 创建账户
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
L2 Trigger influences Right joystick
I've been trying to repair a Dualshock 4 controller (JDM-055) that had the following issue:
Pressing the L2 trigger induced an input on the right joystick's Y axis. So pressing L2 made the camera go up.
What I've attempted: Opening up the controller, cleaning it, and making sure all the contacts were clean and aligned. Once that was done, I test it again on gpadtester and it was still displaying the same fault. So I thought maybe the joystick was faulty and leaking current somehow and de-soldered it. It's still behaving the same even without any joystick there, it just pegs the value further up. Is this a known issue? Is the main PCB toast? I can't think of anything else other than a drifted resistor somewhere or a PCB crack, which probably wouldn't be worth repairing. Any tips appreciated!
Image of what gpadtester looks like when pressing L2 with no joystick installed. When released, the input hovers near the edge of the circle. When pressing, it goes up.
Update (04/26/26)
Hi again, I've changed the circuit membrane, and now the two triggers are stuck on 1 no matter whether I press them or not. I've checked and both the membrane and the gaskets are seated properly. All other buttons are working. The right joystick is still empty. Any idea what the issue could be? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Did you tried to replace circuit membrane?
Would try that first and see what happens!
Guide: DualShock 4 (CUH-ZCT1U) 按键电路膜更换
If that fails, then it is most likely motherboard related..
But would try that first!
这个答案有帮助吗?
得分 1
6条评论:
Thank you for your reply. Yeah that sounds like a sensible step to try. I'll update the situation after the repair
由完成的
My pleasure! Please let us know how it goes :)!
由完成的
I've ordered a circuit membrane and replaced it, and now the R2/L2 Triggers are constantly activated (see updated original post) any idea what that could mean?
由完成的
Are you sure it’s the correct model and that it’s installed as it should?? If yes, please return it, most likely the part is faulty..
由完成的
@dan0 Yeah that looks fishy, I've used another circuit membrane from another controler that works, and this issue disappeared. But the L2 trigger influencing the right joystick is still there so probably there a fault somewhere on the motherboard
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
Léo Beaudoin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 166
