跳转到主内容
加入维修社区 - 创建账户
索尼 DualSense Edge (CFI-ZCP1) 无线控制器于 2023 年 1 月发布。它配备了可更换的摇杆模块,并比 DualSense 有其他多项升级。
Fn button stuck in pressed state
Pad just stuck in profile select mode due to always pressed right Fn button, I swapped the modules and even bought new ones, but it didn't help.
also i have this: 0300e0274c050000f20d000000016800,*,a:b0,b:b1,back:b4,dpdown:h0.4,dpleft:h0.8,dpright:h0.2,dpup:h0.1,guide:b5,leftshoulder:b9,leftstick:b7,lefttrigger:a4,leftx:a0,lefty:a1,rightshoulder:b10,rightstick:b8,righttrigger:a5,rightx:a2,righty:a3,start:b6,x:b2,y:b3,touchpad:b11,misc1:b12,paddle1:b16,paddle2:b15,paddle3:b14,paddle4:b13,crc:27e0,platform:macOS,
So the main question is how to understand what exactly the problem is next, and what to change, since this is definitely not a problem with the stick module.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Then it's most likely something on the board.
Try to clean the connector and inspect if there are any bent pins.
If it's bent, try to fix it.
In the worst case, you need to replace the port or replace the board.
Guide: DualSense Edge 主板更换
If possible, can you sent us some pictures regarding the joystick port?
Thanks!
这个答案有帮助吗?
得分 1
2条评论:
Actually, it sat for almost a year after I bought it. I simply forgot about it. It only showed up after 4-5 days of use, and I didn't have time to replace it. I cleaned the connectors with rubbing alcohol, but everything was still the same. I'll post a photo later, I'm not at home right now. I also thought it might be the motherboard, since there's nothing else there that could cause this. And thanks for the reply! I'll send photo as soon as I get home)
完成的
Thank you! That is most likely it yes. Nothing else should be able to cause this, so far I'm aware of.
Please let us know when you have an update :). Thanks!
完成的
添加一条评论
添加你的答案
Granchik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 104
总计 520
