跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Am I using this program correctly?
Hi so I finally got the analog sticks on my controller these are the Gulikit TMR Joysticks and I dont know whats going out with the right analog stick it clicks, but doesn't register and it looks like it drifts even though they supposed to be new. I tried in BF6 and I don't notice it since I have my dead zone set to 0. Can too much or little solder cause that malfunction?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Hi!
Can you set us pictures regarding the solder work?
在已经存在的问题里加入图片
Thanks!
完成的
Hi, I uploaded the photos it starts from the top going clockwise
完成的
Hi!
Thanks for the pictures! The pads do look damaged in the 2nd and 3rd photos. Can you remove the solder there and sent a photo again? Is that possible? Thanks!
完成的
I will do it as soon as I can
完成的
Hi, I uploaded the removed solder from the 2nd photo I did noticed the exposed copper
完成的
添加一条评论
1个答案
已选择的解决方案
Hi!
It does look like that the pads are damaged, causing this issue.
I’m afraid you need to repair the pads first.
Here is some explanation: https://youtu.be/dtZl7cLYc40?is=0ieMGMQp...
Please let me know how that goes!
这个答案有帮助吗?
得分 1
2条评论:
Thank you I'll just a new MB and analog sticks it always something with this and its getting tiresome
完成的
I understand yes, I would swap it out for a new motherboard as well. Please let us know how that goes! Thanks!
完成的
添加一条评论
添加你的答案
Christopher D 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 136
