跳转到主内容
加入维修社区 - 创建账户
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Weird System Power Issue
My 3DS is having a weird issue. When the 3DS's top screen's hinge is at about a 95-degree angle or less, the system works perfectly. However, if I push the screen farther back, the system fully turns off. I should point out that the system is not modded, meaning it isn't an issue after modding.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
That is weird. If you are OK with it, can you open it up and check the connections on the motherboard?
这个答案有帮助吗?
得分 0
添加一条评论
Hi!
I’m afraid it’s related to the top screen..
I would replace it and test if that worked.
Guide: 任天堂3DS XL LCD显示屏更换
Note: it’s pretty difficult to perform this repair, so please check with the guide if you want to proceed or not.
这个答案有帮助吗?
得分 0
3条评论:
Just be careful with the old screen, because if that's not the problem, I think you would want to return the new screen to iFixit for a refund.
由完成的 分享
Even if I replace the upper screen, why do I need a new speaker assembly?
由完成的 分享
What do you mean? I would only replace the topscreen for now.
由完成的 分享
添加一条评论
添加你的答案
Bobus_Oxen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 151
