跳转到主内容
加入维修社区 - 创建账户
HP Wired Desktop 320M 鼠标是一款可靠、实用的有线鼠标,作为惠普台式机配件系列的一部分发布。它专为日常使用而设计,具备简单的人体工学设计和 1000 DPI 光学传感器,可实现精确追踪。其 USB 连接确保了稳定且无延迟的使用体验,使其成为办公和居家使用的绝佳选择。HP Wired Desktop 320M 耐用、舒适且高效,为寻求可靠、经济实惠外设的用户提供了简单的解决方案。
Scroller is not working
Scroller is not working properly.How to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
I do not know how long you have had this, but if it has been a few years and the scroll wheel is smooth, it is just because of wear and tear, and the easiest way is to buy a new mouse.
这个答案有帮助吗?
得分 0
添加一条评论
I had a similar problem with a different brand of mouse. The axle on the scroll wheel had broken due to excessive stress, so I took the thing apart and used some super glue to stick it back on. Surprisingly enough, it's still holding up, so you might want to try this before you go and buy a new mouse. You have to be careful and make sure the axle is aligned to the spot it broke off from and that it's not crooked, or otherwise the wheel could "wobble".
这个答案有帮助吗?
得分 0
添加一条评论
It's almost always a cracked wheel or the mechanical encoder is broken. Buy a new mouse, they're $10-15 a pop for a basic no frills mouse like the Logitech M100 and many, many private label ones which are often under $10. A mouse is a mouse, as long as it's not a Magic Mouse it will work and is probably ergonomic enough.
I have a nice mechanical keyboard, and yet I still buy $8-20 throwaway mice. I throw more money away on eBay and yard sales then I will spend on a basic mouse (or a spare I got on clearance). if you want to try and see what you can do, take it apart and see but most of the time the mouse is a lost cause. You can get them for $8 at Walmart: https://www.walmart.com/ip/onn-3-Buttons...
这个答案有帮助吗?
得分 0
2条评论:
Like I said, in my case all it took was superglue, so I'd say there's no sense in not trying to fix it at the very least.
由完成的 分享
@fixerofstuff Mice are rarely fixable in my experience, they're almost always something that needs soldering to repair. The 320M is a OEM mouse (I have a Elite Mini 805 G8 which whipped with the 320M/320K and the original box with low SSD hours, I hate that style so I just installed the PC and sidelined the keyboard and mouse). If I needed the mouse, I can buy those all day on eBay in pairs of 3-5 and if you buy a modern Elite Mini/EliteDesk, HP uses the 320K as the default board (the good 125K is optional) and it's built accordingly vs the 125K.
由完成的 分享
添加一条评论
添加你的答案
Vishal Raj 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 55
总计 412
