Where is the O2(lambda) sensor?
When check it in INPA, lambda voltage is constant. I want to be sure if it is connected, after being sure that it is not possible to fix connections I am planning to change it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@orkunarabaci we need to know the exact year and model as well as the engine size. The oxygen sensor is usually located in the exhaust pipe, downstream from the exhaust manifold.
完成的
316i Compact 1999 M43B16
完成的
添加一条评论
