跳转到主内容
加入维修社区 - 创建账户
1994-2004 年款福特野马 (Ford Mustang) 的维修指南与支持,包括 Mustang GT 和 Mustang Cobra。
Have low fuel pressure
Have changed fuel pressure sensors on fuel rail and on gas Tank .Have changed fuel pump .cranks after priming (turning key on and of 3 times ) and ideals if you press the accelerator like normally taking off it will die if you put it in gear and press the accelerator it will die if you slowly float the accelerator and park it will rev up all the way to 3500 RPMs but once you put it in here and mash the gas to go it stalls out. When you just crank it and let it sit there and Auto it autos for a while then it will all of a sudden start missing bogging down and die
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@martyleesmith what exact year and engine size is your Mustang?
完成的
添加一条评论
1个答案
最有帮助的答案
I had a suburban that acted like this. Had me chasing ghosts thinking it was fuel. What fixed it for me? Oddly enough.... spark plugs. It would fall flat on its face unless i was in park. Then I could get the revs up a bit more. I replaced the fuel pump, filter, all that jazz. No difference. Then I replaced the plugs, and it immediately stopped all of that.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Marty Lee Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 110
