跳转到主内容
加入维修社区 - 创建账户
Toyota Vitz 是一款小型掀背车,于 1999 年作为 Toyota Starlet 的继任车型首次推出。它在国际市场上以 Toyota Yaris 或 Echo 的名称销售。目前 Toyota Vitz 已推出 4 代车型。
Why the engine is vibrating too much?
The car's engine is vibrating too much leading to the car being not comfortable to drive
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
3条评论:
When start my car the engine vibrate too much until the car is warmer
由完成的
@guleidahmed here is not enough information to provide you with an answer. you will need to check your fuel pressure as well as your vacuum lines. A vacuum leak can cause this. Have your OBDII scanned for an exact diagnosis.
由完成的
another reason could be engine mounts
由完成的
添加一条评论
1个答案
sounds like most likely you have a misfire. have it connected to a OBD ll and see what codes it throws.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Themba Phiri 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 86
总计 813
