跳转到主内容
加入维修社区 - 创建账户
索尼互动娱乐公司生产的电视游戏主机;PlayStation 4 Slim(CUH-2000 系列)是原版 PS4 的更薄的替代机型。于 2016 年 9 月 7 日发布。
Error code su-42118-6 PS4
My PS4 Slim has random clicking noises at random intervals. My PS4 also cannot update at all and shows the error code "su-42118-6" whenever my PS4 is done updating. It might be a loose blu-ray cable/ribbon. This started after my PS4 refused to read disks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
That error code is pointing towards the Playstation it’s blu-ray drive.
Could be the ribbon cable, power cable or the PCB.
First I would replace the ribbon cable and see what happens. This is most likely the issue here.
Still failing? Try to replace the power cable as well.
Clicking noise is usually the HDD. You can try a known working one as well and see what happens..
这个答案有帮助吗?
得分 1
2条评论:
i have the same problem, i hear that the drive turning on and everything but still the error when i want to update my ps4. i just bought a ribbon cabel... if its not better than pcb. how can i know if its good or not?
由完成的
Yes, probably for the best to test with a new ribbon cable. Sometimes they do fail. If the error is still there, you might need to check the PCB. Do you also have ticking noises?
由完成的
添加一条评论
添加你的答案
209 guy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 38
总计 179
