跳转到主内容
加入维修社区 - 创建账户
提供首款搭载苹果基于 ARM 的 M1 SoC(配备 8 核 CPU 和最高 8 核 GPU)的 13 英寸 MacBook Air 的维修指南、支持和故障排除信息。该机型于 2020 年 11 月发布,型号为 A2337 或 EMC 3598。
Touch ID pairing - Self Service Repair
I am a little confused by the Self-Service Repairs from Apple, and what is and isn't possible.
When I attach a second hand screen (genuine Apple) it gives me the option to finish the repair and it calibrates accordingly.
When I try a second hand Touch ID (genuine Apple) it fails to recognise it as being a genuine part.
My questions are - is it possible to calibrate a Touch ID now through Apple's program? And if so, would I need to buy a new button through the Self-Service Repair from Apple?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I was going through the self repair program information, and every indication is that the Repair Assistant seems to be able to recalibrate a Touch ID board, at least one purchased from Apple. They don't differentiate that repair from any other one they talk about, so I don't know if there is some restriction on only working on one you bought directly from Apple vs. a used part, but it does specifically mention repairing Touch ID on the M1 MacBook Air.
Mac Laptops Troubleshooting Input/Output Issues - Apple Support
Here's the part they're selling; I assume that's what you're replacing.
Self Service Repair Store
They actually show the repair assistant popping up for a new Touch ID board on their guide to invoking it.
Use Repair Assistant to finish a Mac repair - Apple Support
At this point we're really only guessing; only Apple can authoritatively answer the question of why you can't seem to calibrate a used Touch ID board since they show that process in operation. @flannelist Alisha, do you have any thoughts on this?
这个答案有帮助吗?
得分 1
1条评论:
Only a new virgin TouchID button and as far as I know only installed by Apple and the data on the drive is lost
完成的
添加一条评论
You are mixing different aspects of Apples Security
Parts Serialization - To kill off knock off parts (not a real issue) - Using the re-serialization (calibration tool) which only works with real Apple parts.
TouchID - Systems data security - The TouchID is married to the its mated logic board and no other!
这个答案有帮助吗?
得分 0
添加一条评论
I just tested this, because I found conflicting information. A Macbook Air M4 with Find My disabled. I installed a new logic board from selfservice and left the old TouchID in place. It doesn't work, it won't pair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alasdair Sim 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 78
总计 332
