跳转到主内容
加入维修社区 - 创建账户
Meta Quest 3S 混合现实头戴式设备于 2024 年 10 月 15 日发布,比Meta Quest 3 便宜。
How do I fix meta quest 3s controller button?
I got some wd40 to help with a stick drift issue, but some of the wd40 got onto one of the controller buttons, and now it's not responding to my input. I'm still able to press the button, but it doesn't make the same sound compared to the rest of the buttons on my controllers when i press them. It's been quiet after i heard a crunching sound when i pressed it after the wd40 i put on the joysticks was able to dry.
What do i do? Am i able to fix it, or do i need a new controller all together?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
my y buttin just stoped woking and i did not do angoning it looks fine on the outside i dont know what to do
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi!
Sound like the contact of the button is damaged. Depending on which button it is, I would replace it completely and see what happens.
Otherwise replacing the controller is a option, but let's check what we can do first.
Can you also sent us some pictures regarding the button? Thanks!
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
4条评论:
I edited my post to show a picture of the controller. It's the X button that isn't working. Nothing looks broken on the outside from what i can see.
How do i replace the contact of the button? Do i need to open up my controller to access the button contact?
由完成的
Hi!
Yes, you need to open it up and check the button and rubber, clean it both with isopropyl alcohol. And please share a picture regarding the button inside the controller. Inside the controller is where you need to clean unfortunately.
由完成的
I'll try to get my hands on some isopropyl alcohol soon. Do i need a certain tool/method to open up the controller? I don't wanna break the controller by accident.
由完成的
Alright, great!
Yes, you need a Torx (T)5 screw driver, tweezers and a pry tool, like a spudger.
You can find everything in here: https://www.youtube.com/watch?v=EYa9UeDJ... Please follow this one to safely open your controller.
Please let us know how it goes!
由完成的
添加一条评论
添加你的答案
Skitzo Phrenic 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 112
总计 912
