Not charging after water damage
My Iphone got wet. I dried it using all of the tips and tricks but it will not charge. I have disassembled it using the guides and cleaned everything appropriately. It still doesn't charge. When I plug it to the wall charger it will come on but it will not stay on long. When I use the USB charger and a computer I get the apple symbol for a few seconds the it shuts off again. I replaced the battery and everything worked fine until the new battery drained. Now I'm back to square one. What else can I do to repair the charging issue?
3条评论
OK. I just removed the battery and plugged it to the USB on my computer. It still get the apple symbol for a few seconds and then it goes off. So I could use the phone when the battery was charged but the phone still will not come on with direct power to the charge port.
由 Chad 完成的
I have figured out that the two outter pins on my battery connector are shorted. Any ideas on where to look to repair the short?
由 Chad 完成的
On your battery, or on your battery connectors? How do you figured out that they are shorted?
由 oldturkey03 完成的
