跳转到主内容
加入维修社区 - 创建账户
苹果 2021 年的顶级智能手机。iPhone 13 Pro Max 于 9 月 24 日发布,配备 6.7 英寸 ProMotion OLED 显示屏、全新的后置三摄系统以及 5G 连接功能。它是 iPhone 12 Pro Max 的继任者。
My screen is unresponsive
I replace my Iphone battery to a new one, but my screen was unrenposive and was heating while rebooting itself, I tried to turn off but my screen was not responding.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Those FPC connectors like the one for your display can sometimes be tricky to get plugged in correctly. Unplug it again and check it carefully with a magnifying glass and a bright light, looking for bent or broken pins. Be sure to check the connector on the flex cable too. Bent pins can sometimes be straightened with fine tip tweezers. Assuming everything looks good, clean both sides with 90% or higher concentration isopropyl alcohol, give it a minute to dry then reconnect and retest. When plugging in the cable, position it with one hand while using a finger to lightly press down, moving the cable till you feel it fit into the connector. At that point press in the middle of the connector, not the ends, until you feel it click into place.
Give that a try and let us know what you find; that's the most likely issue but of course not the only possibility. it could be the screen got damaged during the process of removal, or maybe the flex cable got torn or broken. We used to have to worry about disconnecting the battery before doing anything with the screen connector, but the OLED screens aren't as sensitive to damage should you neglect that step, but it's still the right way to do it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris from1997 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 18
过去 30 天: 38
总计 169
