跳转到主内容
加入维修社区 - 创建账户
经典 Xbox 无线控制器的第三次修订版于 2020 年 11 月发布,与 Xbox Series X 和 Series S 一起捆绑销售。 该控制器向后兼容以前的 Xbox One 游戏机和 PC。
New TMR Sticks Not Working
I am nee to soldering and know the basics. I replaced both joysticks with new TMR sticks with new Xbox joystick soldering tool. Replacement and soldering went well. But when I go to check controller with Xbox app, it connects but I can't move or use any part of controller. Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi!
Did you tried it here as well > https://hardwaretester.com/gamepad
What is working and what isn't?
由完成的
Nothing works other than the controller turning on and connecting to xbox. I'd post a video if I could
由完成的
添加一条评论
1个答案
Hi!
Thanks for your comment!
Perhaps traces are damaged or the board went to hot.
Please check if everything is connected as it should and also for damaged traces.
I’m afraid your motherboard did die or isn’t connected properly.
Can you check this? Thanks!
这个答案有帮助吗?
得分 0
2条评论:
I will have to check for this a little later, but that may be the case. I'm wondering if I may have had too much heat when desoldering the original analog sticks. Thank you
由完成的
That is possible yes... In this case you most likely want to replace the motherboard, but this isn't cheap...
由完成的
添加一条评论
添加你的答案
kmuetz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 37
总计 239
