跳转到主内容
加入维修社区 - 创建账户
这是 Sony PS2 Slimline (SCPH-750xx) 的故障排除与安装指南设备页面。Sony PlayStation 2 Slimline 计算机系统是一款小巧、纤薄且具备网络功能的游戏主机。
Optical Drive not working.
Heyy,
I had a PS2 Slim (Pink Version) SCPH-77004 with a broken shell (the rest was completely fine)
To replace the shell I ordered a defective and labeled as "Don't Reads Discs)"(Same Type, Same model of course) (might be a different MB Version, didn't checked)
The spare wasn't opened before. Like described it booted and was behaving normal in home screen, it didn't read a disc, but furthermore it didn't seem to even show life of the Laser Assembly (no Motor Spinning, no Laser movement)
That's when I started disassembly, first I checked/tested the two lid switches, both pressed, same result. Both tested good with a multimeter
I tried the working Assembly from my own Slim, and had the same result. The rail tested in my Slim showed Laser Movement and the motor was spinning up. (Didn't read discs, made clicking noises)
I did the same thing with the ribbon cable (so using the ribbon vice versa on both machines) which also provided the same results, I inspected the board of the Spare one and didn't saw any (obvious) issues. And I also checked the Ribbon connectors for lose (cold) connections.
The Spare also didn't looked dirty inside at all, it was like opening a never used console.
So in short:
Laser Assembly good
Ribbon cable good
Ribbon cable connectors good
No obvious MB issue (with Eyes)
Lid switches fine
My question now is, what could it be? Where could/should I start looking for an issue? Did anyone had a similar problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Best thing is to follow this video: https://www.youtube.com/watch?v=Pthhet1_...
It can be way more then the laser and the lid switches (good thing you've checked those, as when they are faulty nothing is moving at all).
I would check your symptoms and see what issue it's having. I think it's something on the motherboard that died...
Can you let us know how it goes?
Thanks!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TheToptic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 98
