跳转到主内容
加入维修社区 - 创建账户
也称 PS2 ,是索尼于2000年3月在日本首发的第六代电视游戏主机。当年稍后时间登陆美国市场,机器型号为 SCPH-30000。维修这款设备只需用到常见的工具,但维修过程可能会有点难度。
How would I restore a PS2?
Hello, I have a PS2 looks to be in need of a restoration. The fan has some visable dust, what looks to be the TV port has dirt (hopefully not bug legs) around the edge of the inside of it. I have not tested it yet and I am wondering where to go from here. Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi!
First, before you disassemble it. Clean it from the outside, clean the fan with a small brush (also the AV port) carefully. And take the dust out.
At last you can also try the vacuum cleaner (low) and remove some dust.
After this test the PS2 and see how it goes.
If it's fine, I would just leave it be. If the fan is making a lot of noise after all of that, then you may want to open it up and remove all the dust further.
Please let us know how it goes!
这个答案有帮助吗?
得分 2
2条评论:
Thank you for the quick responce! I will try this and let you know of the outcome.
完成的
Alright! Thanks! Good luck and you know where to find us :)!
完成的
添加一条评论
🧹 Initial Cleaning
  • Exterior wipe‑down: Use a microfiber cloth with a bit of isopropyl alcohol (70%+) to clean the case.
  • Fan & vents: Compressed air or a soft brush will help remove dust. Hold the fan blades still while blowing air so they don’t spin uncontrollably.
  • Ports (AV/TV, USB, controller): A cotton swab dipped lightly in alcohol can clean dirt around the edges. If you suspect insect debris, carefully remove it with tweezers before swabbing.
Internal Inspection
  • Open the case: If you’re comfortable, remove the screws and lift the shell.
  • Check for corrosion or residue: Look at the motherboard and connectors for signs of rust, liquid damage, or insect nests.
  • Optical drive: Inspect the disc tray and laser lens. A lens cleaning solution or kit can help if it looks cloudy.
Power & Testing
  • Power supply check: Make sure you have the correct PSU and cables.
  • First boot: Test with no disc inserted. Listen for abnormal noises (grinding, clicking).
  • Video output: Connect to a TV and check if the AV port works. If dirty, cleaning may fix poor signal.
⚠️ Safety Notes
  • Always unplug before opening.
  • Ground yourself to avoid static discharge.
  • Take photos as you disassemble so you can reassemble correctly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cperson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 51
总计 373
